mt1801 diesel suddenly started blowing smoke and running poorly
   / mt1801 diesel suddenly started blowing smoke and running poorly #1
somanytractors
atlanta, ga
several
Hi.
My tractor has been running fine.
Just used it yesterday.
Today I was using it for about 5 minutes when suddenly the engine slowed down and it started blowing smoke. Lots of it.
after parking it, I pulled the dipstick and the oil started running out.
I know it didn't have too much oil, but now it seems like it does.
I checked the radiator while still hot. it still has water and had pressure when I opened it.
It has been raining but I don't think there is water in the oil, and it has a hood over the motor so I don't think it could get in there anyway.
The oil is black and NOT foamy so I really don't suspect water.
Is there any way the fuel can get into the motor or something?
Any suggestions would be greatly appreciated.
John
   / mt1801 diesel suddenly started blowing smoke and running poorly #2
Maybe diesel fuel in the oil by the sound of it. Some one else will have to give you advice on how it's getting there.
   / mt1801 diesel suddenly started blowing smoke and running poorly #3
Check hyd oil, if a little bit low then it could be the hyd pump seal.
Thanks for the advice.
I went back out and checked the fuel.
I don't think its missing enough fuel to be the problem.
I think leejohn got it right on the head.
Its probably the hyd pump.
Thanks leejohn.
I think you got it.
The pump has been weak for a month, and thinking back, right before it started smoking today it got so weak it didn't even want to pick up the blade on the 3pt. It did pick it up but it was very slow.
And hyd fluid is the only thing that makes sense considering how over full it is.
Think I'll replace the oil and take the pump loose to see if that fixes it.
If so I'll get another pump. It needs replaced anyway.
Thanks for your help.
Hi.
I drained and refilled the oil with sae 40 to correct level, and I removed the pump.
Its still blowing white smoke, not near as bad as before but enough to be a bit of a problem.
It didn't smoke before. I'm wondering if it broke a ring, bent a rod, or maybe blew the head gasket.
Any suggestions?
Is there anything minor having too much oil could have done to the motor?
And if it does need internal parts, any idea where to find rings? Could I possibly put used rings in it if necessary?
I did notice it does better hot then cold, and I noticed gasket cement on the water neck. I don't know if it has a thermostat. Anyone know where to get one?
found parts
2006 Crimson Spartan Fire 105ft. Quint Ladder Aerial Truck (A52377)
2006 Crimson...
2022 CATERPILLAR 242D3 SKID STEER (A51406)
2022 CATERPILLAR...
2010 Ford F-750 Stellar 10621 10,000LB 5 Ton Crane Mechanics Truck (A51692)
2010 Ford F-750...
UNUSED Jack Lift 5/10 Ton (A53117)
UNUSED Jack Lift...
1979 MACK R MODEL (A53843)
1979 MACK R MODEL...
2016 Ford F-250 Ext. Cab Pickup Truck (A53422)
2016 Ford F-250...
