MT180 drawbar, 3pt stabilizer, and 4wd questions. Also some front end loader capacity info.
   / MT180 drawbar, 3pt stabilizer, and 4wd questions. Also some front end loader capacity info.
Piloon, I do think it's on the wrong tires. The back set is on custom wheels, so that part makes some sense. The fronts are trailer tires and suck, I have been looking for new ones.
For the 4wd, I am talking the lever on the left side of the tunnel, not the diff lock by the right heel (what an annoying spot for that, by the way. I guess a holdover from hand hydrostatic control?)
I have a bit of front end squeal when turning, especially with the loader full, need to see what I can lube there.
   / MT180 drawbar, 3pt stabilizer, and 4wd questions. Also some front end loader capacity info. #12
I have an MT180D as well. 4WD is the small black handle to the right of the tunnel, and simply moves forward a few inches to engage. The diff lock is under the right heel and will only engage when one wheel is already spinning and will not remain engaged once released.
Both turfs and ag tires were available for this tractor. The original turfs were a diamond tread pattern though.
V.E. ENTERPRISES 500 BBL FRAC TANK (A58214)
V.E. ENTERPRISES...
2025 MACK GRANITE GR64F DUMP TRUCK (A59823)
2025 MACK GRANITE...
2012 International 4300 Reefer Truck (A56438)
2012 International...
2021 KENWORTH T680 TANDEM AXLE SLEEPER (A59575)
2021 KENWORTH T680...
2001 WELLS CARGO 8' X 32' TOY HAULER DBL AXLE TRL (A57192)
2001 WELLS CARGO...
2020 FREIGHTLINER CASCADIA 126 TANDEM AXLE MID ROOF (A59575)
2020 FREIGHTLINER...
