MT125 Seat Safety Switch
   / MT125 Seat Safety Switch #1
jdeilus
Prince George, VA
LS MT 125 (still waiting for delivery)
I noticed that something was not normal with the switch. I thought when you get off the seat when the tractor was running and the brake is not set, the engine is supposed to shut off. It did a few time and a few times it didn’t. A few days ago when the tractor was running as soon as It started to move, it would cut off. I knew right off that the seat safety switch was the culprit. I flipped the seat up and noticed that the wiring to the switch was crushed. I have a backhoe on mine so the seat raises and rotates. I believe the wiring, will get crushed If you don’t ensure it feeds back into the hole when moving the seat into its lower position. I’m not sure if this is a manufacturing issue, but keep an eye on the wiring. I have the wire jumped right now until a new switch comes in.
   / MT125 Seat Safety Switch #2
I had the same thing happen to my mt125 about a month ago. I had positioned the seat to use the backhoe and sat down. Tractor immediately shut down and refused to do anything. I too immediately suspected the seat switch wiring as it was unsecured under the seat. After doing some checking I found a 30 amp fuse inside the cowl to be blown. I checked the wires under the seat and both had scraped the insulation down to the wire thus causing the short circuit. I repaired the wires and replaced the fuse. The tractor immediately restarted and has run fine since. I did zip tie the seat wire to one of the tie rods under the seat to prevent this loose wire from again being pinched.
John Deere 1770 Conservation 16 Row Planter (A50774)
John Deere 1770...
Cruise Car Electric Utility Cart (A51691)
Cruise Car...
2007 Ford F-150 Crew Cab Pickup Truck (A50323)
2007 Ford F-150...
Unused 2025 CFG H15 Mini Excavator (A50322)
Unused 2025 CFG...
2013 Chevrolet Traverse LS SUV (A50324)
2013 Chevrolet...
John Deere 1110 Field Cultivator - Heavy-Duty Soil Finisher for Precision Tillage (A52748)
John Deere 1110...
