Rool
119 hard hrs on her. Trouble free until today/yesterday.
Turn the key full lights and a click from the engine. To me it doesn't exactly sound like a solenoid but probably is. Turn the key another position and should turn over engine, but nothing, nada, zilch.
Yesterday this happened once, but then I tried it again and it started up. Today, not even able to turn over once.
Yesterday I had the pedal cotter pin slip out, so I had to pull the floor which required me to to pull the shroud which has the key and cruise control on it. I disconnected both to get it out of the way of me removing the floor. Reconnected it and it seems to be a new problem. I did check both fuses that are found under there and both were good.
Any advice or insight is much appreciated.
