MSRP list
/ MSRP list #1
artp
Southern Illinois
Kioti CK30HST
Does anyone have a site for MSRP list for Kubota tractors? I know prices do vary from region to region. I am in Illinois. Feel like I am unprepared when talking to dealers.
/ MSRP list #2
As far as I know the MSRP for every Kubota tractor is listed on the Kubota website. After selecting the tractor you are looking for there will be a link on top tittled "Build my Kubota". When you are done inputing your options and attachments it will give you the total MSRP. At least that's how I went about it. Dealer prices will obviously vary from dealer to dealer and region to region. Good luck.
Chirobota
/ MSRP list #3
For some reason, I can get to the "Build My Kubota" but then the link doesn't work for me.:confused: So I've never seen the prices on their website.
/ MSRP list #4
The page with the prices will open in a new window or sometimes in a different window that is already open. I tried it with Internet Explorer 7.0 for the L and M series and it works OK. Also worked with Firefox 2.0. Maybe you are not seeing the new window open at the bottom, or perhaps some browser option or popup blocker is stopping it.
/ MSRP list #5
It is peculiar. I'm using Windows Vista, the cursor does not change from an arrow to the little hand to indicate a link, and I get no indication of a pop-up being blocked (which I do get occasionally other places), so I don't understand why I don't get that to work as a link. Although I'd assume you're right; that it's something to do with my computer.
/ MSRP list #6
It doesn't work for me either.
/ MSRP list #7
Well....Windows Vista....enough said...
I've been migrating to Macs for the past 18 months.
Mike
/ MSRP list #8
The cursor does not change like a link. You do not click it, just roll the cursor over the words "Build My Kubota" and more choices should show up in a dropdown list, like tractor model#, then more choices that you roll over like cab/no cab, 2WD/4WD, what transmission etc. Finally on the last choice you will click and the prices show up. Their webpage probably uses Java script and something on your computer is stopping it. I assume you have all the latest Vista and Java updates installed.
I am using XP Service Pack2, IE 7.0, and the Internet Security level is set to "Medium-High" (default).
/ MSRP list #9
downslope said:
The cursor does not change like a link. You do not click it, just roll the cursor over the words "Build My Kubota" and more choices should should up in a dropdown list, like tractor model#, then more choices that you roll over like cab/no cab, 2WD/4WD, what transmission etc. Finally on the last choice you will click and the prices show up. Their webpage probably uses Java script and something on your computer is stopping it. I assume you have all the latest Vista and Java updates installed.
I knew if you hung in there long enough, you'd get it diagnosed.:D Thank you. I don't know what happened, but I went to another site that I knew used Java and found it wasn't working either (it had in the past). Anyway, I downloaded the latest edition of Java and the Kubota prices work now. I appreciate your patience and help.
Kivel Skid Steer Forks (A65640)
Kivel Skid Steer...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A65643)
2020 TROXELL...
2013 PETERBILT 365 (A65643)
2013 PETERBILT 365...
2020 Kawasaki Mule Pro DXT (A62613)
2020 Kawasaki Mule...
2011 Ford F-550 Truck 4x4 (A62613)
2011 Ford F-550...
HEAVYEQUIPMENT TIRES (A65643)
HEAVYEQUIPMENT...
