ms310 not starting
   / ms310 not starting #1
dirt clod
panama city and altha florida
Kubota L3300, m5700, case 580se
my sthil ms310 will not start unless I spray carb cleaner in carb. I've took apart carb and sprayed out with cleaner. replaced fuel hose. Any ideas what to check next?
   / ms310 not starting #3
Two suggestions:
post your question in the chainsaw forum here. You'll likely get more responses there. Second, when you say it'll only start if you spray carb cleaner in it, do you mean when it's cold, or regardless of engine temperature?
   / ms310 not starting #4
The ONLY time my 310 would not start is when I put the chain oil in the gas tank.... Oops.....
Any chance you did that?
Other than that, is the fuel clunk still attached?
Wayne
BUYER'S PREMIUM INFO (A53084)
BUYER'S PREMIUM...
NEW 24ft Feed Bunk Wagon (A55218)
NEW 24ft Feed Bunk...
2016 Ford F-750 14FT Flatbed Truck (A52377)
2016 Ford F-750...
2014 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A54313)
2014 FREIGHTLINER...
2012 Trail-Eze TE801 48ft 50 Ton Slide-Axle T/A Tilt Trailer (A51691)
2012 Trail-Eze...
UPDATED INTERNET BUYER'S PREMIUM TERMS (A50775)
UPDATED INTERNET...
