ms310 no fuel
/ ms310 no fuel #1
dirt clod
panama city and altha florida
Kubota L3300, m5700, case 580se
Can start with carb cleaner and dies soon as cleaner is used up. I have replaced fuel hose , cleaned fuel filter, cleaned carb. Problem started after I took saw apart to replace broken brake handle. Could there be a tiny hole in the pulse hose from carb to crank case? Any other ideas to check?
/ ms310 no fuel #2
There could be a hole in the pulse hose. Worth a shot anyway.
And I am not familiar with that model, but I had a similar case on a husky 266se. There was a plastic spacer that went between the cylinder and the carb. It could go on either way, BUT, there was a hole on one side that mated to the pulse port on the jug and carb. It was backwards.
It isnt that hard to take the carb back off and double check everything. Since you said it WAS running before, my guess is that something was missed when put back together. Pinched hose?? cracked hose?
/ ms310 no fuel #3
I have a 310 IPL and service manual. I would be looking at the impulse line and then make sure you put the carb back together in right order. Diaphragms and gaskets etc. ;)
1996 International Water Truck with a Caterpillar Engine (A63688)
1996 International...
New/Unused Landhonor Hand Chain Lever Hoist (A65583)
New/Unused...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2015 Chevrolet 15 Passenger Express Van (A62613)
2015 Chevrolet 15...
Snap-On Zeus Diagnostic Machine (A63689)
Snap-On Zeus...
2022 EZ-GO ELITE...
