Mpower85
/ Mpower85 #1
Dickey
Tyro, Arkansas
M5700, L245DT and Mahindra mpower 85
I have a Mahindra Mpower 85 with a tandem hydraulic pump their is a fill port on the front of it I need to know what kind of lubricant goes init and if you fill it to top of fill port?
/ Mpower85 #2
A "fill port"? What exactly is that? There should be a suction manifold with a line leading the hydraulic filter, but a fill port sounds a bit strange.
/ Mpower85
I think it is called a swing bearing, it’s on the front of the tandum pump behind the fan belt pully. Their is a reservoir with a black fill cap about the size of a silver dollar
/ Mpower85
I haven’t been able to find anything in the owners Manuel about it
/ Mpower85 #5
There is a "cap, oil filler" listed in the parts book. It apparently fits into the front timing cover on the right side, probably right over the drive shaft and gear for the hydraulic pump. My guess is this is a filler port for engine oil. I doubt it's a reservoir at all. Where do you add motor oil?
/ Mpower85 #6
Sure do hate when these threads simply end without giving the final results.
2024 CATERPILLAR 68" HYD 4IN1 BUCKET (A62129)
2024 CATERPILLAR...
2011 Ford F-250 RKI Service Truck (A61573)
2011 Ford F-250...
2005 Sterling Acterra Tender Truck (A63688)
2005 Sterling...
(5) 2" X 20' STEEL PIPE (A64281)
(5) 2" X 20' STEEL...
John Deere 6130M (A64126)
John Deere 6130M...
2011 Porsche Panamera Sedan (A61574)
2011 Porsche...
