Mpower85
   / Mpower85 #1
Dickey
Bronze Member
Tyro, Arkansas
M5700, L245DT and Mahindra mpower 85
I have a Mahindra Mpower 85 with a tandem hydraulic pump their is a fill port on the front of it I need to know what kind of lubricant goes init and if you fill it to top of fill port?
   / Mpower85 #2
A "fill port"? What exactly is that? There should be a suction manifold with a line leading the hydraulic filter, but a fill port sounds a bit strange.
   / Mpower85
I think it is called a swing bearing, it’s on the front of the tandum pump behind the fan belt pully. Their is a reservoir with a black fill cap about the size of a silver dollar
   / Mpower85
I haven’t been able to find anything in the owners Manuel about it
   / Mpower85 #5
There is a "cap, oil filler" listed in the parts book. It apparently fits into the front timing cover on the right side, probably right over the drive shaft and gear for the hydraulic pump. My guess is this is a filler port for engine oil. I doubt it's a reservoir at all. Where do you add motor oil?
   / Mpower85 #6
Sure do hate when these threads simply end without giving the final results.
UNUSED FUTURE MINI SKID STEER HYD HAMMER (A51244)
UNUSED FUTURE MINI...
2017 Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
2017 Bad Boy...
Hesston 565T Round Baler (A50514)
Hesston 565T Round...
2015 Silverado 1500 (A50323)
2015 Silverado...
2019 Nissan Sentra Sedan (A50324)
2019 Nissan Sentra...
2017 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A51242)
2017 CATERPILLAR...
