Mowing Mowing.
/ Mowing. #1
atk_man
Duncan, BC, Canada
1979 Kubota B7100D
OK here we go, it will be my first time mowing on the weekend. I'm using a 79 B7100 and a finishing mower. I've been told to run at 2800 rpm which give about 540 on the pto. It sure sounds like the little beast is screaming at that speed. Tell me it isn't going to blow apart after running that high for a few hours.
Thanks.
/ Mowing. #2
I think that is way to fast. Is this a finish mower or brush hog? doesn't matter really as long as the size matches your hp you should be around 2000rpm give or take 200-300 listen to the motor and adjust ground speed for most efficiency. Finish mower blade sharpness will make a difference too.
Just because it is 540 pto implement doesn't mean it has to be working at that speed
/ Mowing. #3
<font color=blue>Tell me it isn't going to blow apart after running that high for a few hours</font color=blue>
OK, it won't! Does that machine have a tach? My '95 B7100 did not. But PTO speed is only a couple hundred rpm below wide open, and you can't over rev it and hurt it.
/ Mowing. #4
I used to just slightly back the throttle off from full on a B5100E. This was using the MMM with a front, electric clutch PTO. It did sound like it was too fast at first, but that's the way the manual said.
/ Mowing.
No, It doesn't have a tach.
That's what I was told too, a couple hundred below full. Full being 2800 rpm.
It just sounds high. I'm guessing in a lot of cases, there isn't enough power to run in PTO-2 at lower rpm.
/ Mowing. #6
B7100 - 16 PTO hp? It depends on what you're cutting. You don't want the engine to lug. Dick Bargeron might have something to say here - he uses PTO 2 for snowblowing with good results, but that's on an L5450. Is your PTO 2 980 RPM or 750. 980 might be a little too high (engine RPM too low).
/ Mowing. #7
deisel engines have a governer on them,
should be able to run full throttle all day no problem...
/ Mowing. #8
When useing my rear mower on dry..about 5" high of grass,the throttle set about 3/4 plus I over lap the fresh cut grass 1/4 w/the deck.
Slower speed and sharpen blades makes a big differents{also if you can sing a song which I can't /w3tcompact/icons/eyes.gif} for it may take a while longer.
/ Mowing. #9
atk man
I always ran my 7100 at full RPM's then backed it off a little. Yes it did sound like it was running to fast. But you will get used to it after a while. Wear hearing protection when running it. This will help and also protect your hearing.
/ Mowing. #10
I used to run my B7100 around 3/4 throttle when mowing with a 54" deck and it was just about right. I would increase it a bit if I saw tall grass ahead so not to lug the motor. Never was back to the dealership.
/ Mowing. #11
For 30 some years I used a Case DC with a bush hog or sickle bar mower and was used to the sound of the engine thumping along at its 1300 RPM "red line".
When I got my B7300 and first reved it up to 2800 (540 PTO) I thought the same thing as you. . . it's gunna blow itself apart, but so far in 100 hours and a year and a half she's still screamin' away!
/ Mowing. #12
I never run my tractor at the suggested RPM in part because I am still in the break in period and it also hasn't seemed to need to run at that high an RPM for cutting the grass. The first time I cut the lawn I let it get very high as it was a new lawn. I was stopping every three passes to empty my bags...quite a pain. It had no problem whatsoever keeping the RPM around 2200 or 2300 rpm. Mine even sounds worse with the addition of the grass collection system. Reminds me of a multi engine aricraft.
That said, I want to second the comment on the hearing protection. I spent last Saturday out doing some fel work and grading. When I came in the house I had a persistant whistle in my ears which lasted for 2 days. Won't do that again.
Jeff
2001 B7500hsd, la302fel, 60"mmm, grass catcher
/ Mowing. #13
<font color=blue>never run my tractor at the suggested RPM </font color=blue>
I guess I'm just the opposite. I varied the RPM a lot during the first 50 hours; still do when I'm not using a PTO powered implement, but when running the PTO powered equipment (finish mower, rotary cutter, and tiller), I always run it at the PTO rated speed. And when I drive the tractor down the road occasionally, just pull the throttle wide open./w3tcompact/icons/laugh.gif
2015 Audio Q5 SUV (A64557)
2015 Audio Q5 SUV...
20 Ton Air/Manual Hydraulic Bottle Jack (A64557)
20 Ton Air/Manual...
2012 Ford F-450 4x4 Liftmoore 1640 4,000lb. Crane Service Truck (A64556)
2012 Ford F-450...
2002 Harmon Steel Barrel 7,000 Gallon Asphalt T/A Tanker Trailer (A64194)
2002 Harmon Steel...
JOHN DEERE HX14 ROTARY MOWER, 3PT (A64278)
JOHN DEERE HX14...
JENDRIX & DIAL UNDERCUTTER, 3PT (A64278)
JENDRIX & DIAL...
