Mowing with a track machine
/ Mowing with a track machine #1
jmfox
Platinum Member
I am planning on using an ASV SR80 to clear a 40 acre site. I know this machine works well for leveling, clearing, mulching and tree cutting, but I would also like to use it to mow some high grass. So I'm wondering what I can expect from a mower attachment on a track machine. I don't expect to a fine cut, but I was hoping to cut down a field to a nice even 4 inches.
jmf
/ Mowing with a track machine #2
It can be done, but your turns on a track machine will be leaving some marks.
/ Mowing with a track machine #3
I have a front mounted brush hog on my Power Trac PT425. It is run by a hydraulic motor rated at 8GPM and 2500PSI. It will obliterate anything under an inch and a half.
Here's a couple links to some videos of it in operation:
http://www.mossroad.com/PT425Videos/PT425DeepWeeds1.WMV
http://www.mossroad.com/PT425Videos/PT425DeepWeeds2.WMV
http://www.mossroad.com/PT425Videos/PT425FieldClearing.WMV
If my little 25HP PT425 can do this, I think your ASV SR80 should have no problems powering a brush hog. The hard part will be finding a unit that runs off of hydraulics for a decent price.
/ Mowing with a track machine #4
When I priced skidsteer brush cutters about 6 months ago, I was seeing $4000-6000 for the cutter. You might be able to rent one locally for maybe $100/day if you only need to use it occasionally.
Depending on your overall plans you might also consider getting a cheap, old, 2wd tractor with a basic cutter. A functional tractor and cutter could probably be had for under $4000 total.
2020 Doosan DX35 (A64911)
2020 Doosan DX35...
1143 (A63745)
1143 (A63745)
2006 HEIL 200BBL CRUDE TANKER (A67714)
2006 HEIL 200BBL...
CATERPILLAR D9T CRAWLER DOZER (A64279)
CATERPILLAR D9T...
2015 WILDWOOD 5TH WHEEL (A67714)
2015 WILDWOOD 5TH...
2018 John Deere 5125R Tractor (A64047)
2018 John Deere...
