Mowing with a track machine
/ Mowing with a track machine #1
jmfox
Platinum Member
I am planning on using an ASV SR80 to clear a 40 acre site. I know this machine works well for leveling, clearing, mulching and tree cutting, but I would also like to use it to mow some high grass. So I'm wondering what I can expect from a mower attachment on a track machine. I don't expect to a fine cut, but I was hoping to cut down a field to a nice even 4 inches.
jmf
/ Mowing with a track machine #2
It can be done, but your turns on a track machine will be leaving some marks.
/ Mowing with a track machine #3
I have a front mounted brush hog on my Power Trac PT425. It is run by a hydraulic motor rated at 8GPM and 2500PSI. It will obliterate anything under an inch and a half.
Here's a couple links to some videos of it in operation:
http://www.mossroad.com/PT425Videos/PT425DeepWeeds1.WMV
http://www.mossroad.com/PT425Videos/PT425DeepWeeds2.WMV
http://www.mossroad.com/PT425Videos/PT425FieldClearing.WMV
If my little 25HP PT425 can do this, I think your ASV SR80 should have no problems powering a brush hog. The hard part will be finding a unit that runs off of hydraulics for a decent price.
/ Mowing with a track machine #4
When I priced skidsteer brush cutters about 6 months ago, I was seeing $4000-6000 for the cutter. You might be able to rent one locally for maybe $100/day if you only need to use it occasionally.
Depending on your overall plans you might also consider getting a cheap, old, 2wd tractor with a basic cutter. A functional tractor and cutter could probably be had for under $4000 total.
2015 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A61573)
2015 Chevrolet...
Ford 3910 Tractor w/ Great Bend Loader (A64047)
Ford 3910 Tractor...
2012 Caterpillar Warren Power Systems WCW204MH 20KW Towable Light Tower (A64194)
2012 Caterpillar...
2017 Scag SCZ72V Cheetah 72in. Zero Turn Commercial Mower (A64194)
2017 Scag SCZ72V...
2004 Caterpillar 315C Hydraulic Excavator (A64194)
2004 Caterpillar...
2004 160 LC John Deere Excavator (A62613)
2004 160 LC John...
