laurencen
- Joined
- Feb 19, 2007
- Messages
- 1,211
- Location
- saskatchewan Canada
- Tractor
- Bobcat Toolcat 5600T Kioti CK20, Cat D2 dozer, Cat 420 tractor loader, Deer 644E loader, Bobcat E32 mini and Bobcat 590 skidsteer, Toro Groundsmaster 325D
Hi all, got a ck20 gear and mowing with a 5 foot rough cut mower, need advice, how do you start off and stop, I am putting in gear, applying throttle loose out the clutch adding more rpm, to stop I am dis engaging the pto then the clutch as if simply depressing the clutch it makes a awfull noise.
on another note, I am having issues keeping the turnbuckles tight, if mowing ditches the mower will eventually contact the tire due to the turnbuckle coming loose and allowing the mower to move sideways, I have tried tightening the turnbuckles tight but it comes loose, maybe I have it too tight
thanks in advance
Laurence
thanks in advance
Laurence
