Mowing mowing with a rough cut
   / mowing with a rough cut #1
laurencen
Veteran Member
saskatchewan Canada
Bobcat Toolcat 5600T Kioti CK20, Cat D2 dozer, Cat 420 tractor loader, Deer 644E loader, Bobcat E32 mini and Bobcat 590 skidsteer, Toro Groundsmaster 325D
Hi all, got a ck20 gear and mowing with a 5 foot rough cut mower, need advice, how do you start off and stop, I am putting in gear, applying throttle loose out the clutch adding more rpm, to stop I am dis engaging the pto then the clutch as if simply depressing the clutch it makes a awfull noise.
on another note, I am having issues keeping the turnbuckles tight, if mowing ditches the mower will eventually contact the tire due to the turnbuckle coming loose and allowing the mower to move sideways, I have tried tightening the turnbuckles tight but it comes loose, maybe I have it too tight
thanks in advance
Laurence
   / mowing with a rough cut #2
On the turnbuckle issue. Does your CK have the setup where the pin holds these stabilizers at certain lengths? Or is it meant to be threaded in and out to adjust tightness? I have had trouble with stabilizers coming loose from the lower 3ph arms when a bolt that is meant to stay tight gets loose. It's one of my mid-mow checks.
   / mowing with a rough cut #3
Thanks, mine uses a turnbuckle, left and right hand threads so it tightens, there is a locknut, this is on both arms to setup side to side play and the one on the top link, no matter how tight I set the nut it comes loose, I am talking about 1 hour of cutting,
Still need advice best way to start cutting and stopping the mower without the aufull noise
Laurence
   / mowing with a rough cut #5
Your starting and stopping method is correct. The "noise" you're referring to is the built in pto "over run" clutch that all ck20 gear drives have.
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
Super Star Smithco Bunker Rake (A50324)
Super Star Smithco...
Land Honor Skid Steer Backhoe Arm Attachment (A50515)
Land Honor Skid...
2014 Nissan NV200 Cargo Van (A50323)
2014 Nissan NV200...
