MHarryE
Elite Member
- Joined
- Feb 15, 2009
- Messages
- 2,972
- Location
- Northeastern Minnesota
- Tractor
- Kubota M7-171, M5-111, SVL75-2, RTV900XT & GR2120; CaseIH 1680 combine
At your tractors age (22 - 24 years) and without your knowing its service history, I would suspect worn hydro components.  First thing is to check propel pressure and make sure it is reaching 3500 psi.  You probably already know your tractor was built by Hinomoto.  If your OMM gives any indication where to check propel pressure, plumb in a gauge and see what kind of pressure you get when the tractor stalls out.  There should be a way to adjust the high pressure relief (possibly 1 relief for forward and 1 for reverse) to compensate.  I can't think of any real wear point in these direct acting reliefs but springs can lose tension with time and heat, and the relief pressure is set at a given flow rate through the relief.  If the pump is no longer capable of producing this flow, the relief will need to be readjusted to compensate.
