Mowing Mowing Septic tank
   / Mowing Septic tank #11
Steve,
I have been mowing over mine for 3 years now with my L3410 and 700 lb mowing deck. I have not had any problems.
I am more concerned with the leach field then the septic tank. Anyone know what the leach fields are generally made of? Are they concrete or just crushed rock?
   / Mowing Septic tank #12
Repairs to the building you say, check this out...
   / Mowing Septic tank #13
...and a bugger to get the fork lift out...
-david
   / Mowing Septic tank #14
Thats what I call having a real bad day!!
   / Mowing Septic tank #15
I think they were still in the demo phase of the project, but I don't think they planned on the septic tank. The crazy thing is that he runs a highway construction company and has an excellent safety record.
-david
   / Mowing Septic tank #16
Your leach field (if it is current) should consists of washed gravel , and plastic pipe. No normal tractor that anybody would be finish mowing with will hurt it.
As for the septic tank, if it is a concrete tank of recent vintage, you again will be safe. Be very careful of old steel tanks. They have not been used in many areas in 20+ years, and often have rusted .
   / Mowing Septic tank #17
Alot depends on the tank, a concrete tank will hold alot more than you might think. A steel tank, well, I had a neighbor who went through his while walking across the lawn. Steel does rust rather quickly underground. Some much older homes still have cedar tanks. My fathers caved in all by itself, and a neighbor lost his craftsman in his. No one wanted to dirve it after that, go figure./w3tcompact/icons/laugh.gif There are also plastic tanks out there, which I wouldn't trust with anything larger than a hand mower.
You could always find someone you aren't overly fond of, and let them try out your tractor over the tank. (Kidding, just kidding) (even though I could think of a few)/w3tcompact/icons/laugh.gif
   / Mowing Septic tank #18
In addition to gravel in leach fields you might find chomped up tires as a gravel substitute. Said to work marginally better and saves on labor during construction due to light weight. There are leach fields that have hollow voids where traditionally there has been gravel (and now sometimes chomped up tires). The "Infiltrator" is one such system. It is reputed to work better than gravel or tires and hence "code" in this state allows fewer linear feet of Infiltrator than an equivalent gravel or tire installation. I would be very nervous driving much of anything over an Infiltrator leach field.
The septic installer I hired for my mom's tank and leach field was a cautious expert. When I asked about driving over the leach field with my tractor he said to minimize it due to compaction considerations. when I asked it I could drive over it with the tractor to till the surface, he said OK but only till the top couple inches. I don't recall getting any amplification on that.
Hope this helps...
Patrick
   / Mowing Septic tank #19
Will,
Do you know how deep leach fields usually are?
   / Mowing Septic tank #20
MrP. They are usually rather shallow, only as deep as you need to get grade away from your septic tank. Except in unique situations, somewhere between 1-3 feet beneath the surface would be the norm.
2017 BOMAG BW211 DH5 SMOOTH DRUM ROLLER (A52707)
2017 BOMAG BW211...
2018 JCB Truss Jib Telescopic Hydraulic Boom (A53421)
2018 JCB Truss Jib...
(2) GAS HEATERS (A54757)
(2) GAS HEATERS...
2018 CHEVROLET SILVERADO 2500HD (A55745)
2018 CHEVROLET...
2004 INTERNATIONAL 9400I DAYCAB (A55745)
2004 INTERNATIONAL...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50323)
BW RVB3405...
