Mowing Mowing MPH
/ Mowing MPH #11
WOW! You guys really cover some ground! I mow at about 2mph. My Mitsubishi D2000 (24 hp) tractor and Woods RM-59 finish mower do a wonderful job at this speed. Never occured to me to try to go any faster.
/ Mowing MPH #12
We too went with the ZTR for finish mowing. Dixie chopper 60" cut running as fast as possible/comfortable. I'm not sure what the MPH are but it's got to be around 8 or 9 MPH average.
/ Mowing MPH #13
Im pretty consistant at 3.0-4.5 mph depending on grass depth or ground roughness.
/ Mowing MPH #14
Can't really brush cut with those bad boys though, can you? ( say.. 1.5' - 2' material.. up to 1/2" stems.. mostly green, some woody and brambles.. etc. broadleak weeds.. occasional grass (grin) )
Soundguy
Dargo said:
I can only go about 3.7 to 4.5 with my 7' RFM on my tractor and keep a decent cut (has digital speedo). Any faster and I have some grass sort of stand back up later. With the Grasshopper front mount ZTR mowers I have with 61" cuts each, I paced them at 11.1 to 11.3 MPH while still keeping a great cut. I guess that's why I spent the money for a couple of them rather than mow with the tractor. Even with smaller widths, they mow considerably faster; especially when you take the quality of cut into consideration.
I doubt that the RFM's have anywhere near the blade tip speed of the ZTR's based on what I've experienced. I know some companies post the blade tip speeds, but I don't recall any.
/ Mowing MPH
I guess I could go a little faster, I'll have to experiment and see if the quality of cut suffers.I have noticed that I can go a bit faster with the hi-lift blades installed. Right now I'm running the lo-lifters due to the horrific amount of dust generated by the hi-lifters. Also, how often do you sharpen your blades? What do you use for blade sharpening?
John
/ Mowing MPH #16
We keep an extra set of blades in the pole barn and swap them out when the existing set gets dull.
An angle grinder touches up the spare set real quick.
/ Mowing MPH #17
Sure does. i just did some blade sharpening last week.
One thing i gotta say. After using 3pt mowers for years.. and then getting a batwing... Boy.. is it sure easier to get to the blades...No more jacking and cribbing the deck to get at them... Just fold the wings then you have verticle access to 4 blades, and easy horizontal access tot he other two... No jacking or cribbing needed...
Soundguy
/ Mowing MPH
Ridge, How long does it take for them to get what you consider "dull". That's a somewhat subjective term. I always hit them with the angle grinder and then really dressed them up with a big ******* file. Also, are you concerned with the balance of the blade after sharpening? I could see where the balance check could be easily ommited with the batwing mower.
Thanks,
john
/ Mowing MPH #19
I've never ballanced a a lawnmower blade any more than by eye, and perhaps with a finger thru the hole.
It's pretty easy to tell when a blade is out of balance as the mower should vibrate. My deck on my cheapo murray will run smooth with no vibrations untill you loose a chunk of blade .. like on a rock.. etc.. and you know it immediatly too! It doesn't take much breaking or wearing off to tell ( by feel ) the blades are out of ballance, or bent.. etc.
Soundguy
/ Mowing MPH #20
John I kinda watch the grass that I've just mowed. If the blades of grass aren't squarely cut or appear jagged or torn the mower blades get replaced with a sharp set. Depending on how careful I am when mowing around the gravel drive sometimes I can get a decent cut for 3 months on a set.
I hammered a nail in the end of a short piece of 2 X 4. I put it in the vise and hang each blade from it through the blade hole to be sure they are still somewhat in balance. I also check them with a straight edge to be sure one or more isn't bent. Pretty easy to straighten a blade that isn't to badly bent.
2004 MCI D4500 Bus, VIN # 1M8PDMPA44P056241 (A61165)
2004 MCI D4500...
2005 Big Tex Utility Trailer (A60352)
2005 Big Tex...
2020 DRAGON 150BBL ALUMINUM (A60736)
2020 DRAGON 150BBL...
1983 INTERNATIONAL S SERIES WATER TRUCK (A57192)
1983 INTERNATIONAL...
2014 KEYSTONE COUGAR CAMPER (A60736)
2014 KEYSTONE...
TULSA WINCH (A60736)
