WinterDeere
Super Star Member
- Joined
- Sep 6, 2011
- Messages
- 12,863
- Location
- Philadelphia
- Tractor
- John Deere 3033R, 855 MFWD, 757 ZTrak; IH Cub Cadet 123
My 2020 model year 3033R with mid-PTO option also has this. I believe it only activates when I select the mid-PTO, but I honestly don’t mow with that machine, so I haven’t tested it. It is not an issue with the rear PTO, I have run a rear snowblower on that machine without having to hit the bypass at all.So this is begging the questions: at what point/size does this not become a required feature? Is it only sub-compacts? only those models frequently sold/marketed with a mid-mount mower? ...and is it only tied to having an implement/load on a mid-PTO? (would seem to become a real nuisance when using a 3pt snowblower)
Just curiosity on my part
... and to answer the OP’s no.3 question, if the PTO stops (eg. you forget to overrride before reverse), then yes... you should throttle down to re-engage the PTO. However, once you learn to get used to remembering the override switch, the PTO will not stop when you reverse.
