Mowing mowing in high gear
/ mowing in high gear #1
kokopelli2
central maryland
kubota/b2910
has anyone had a problem with mowing in high gear? does anyone out there mow in high gear. i haven't yet and am afraid to since my dealer told me not to. i just received my b2410 hts. i usume it has the power to do so, but dont want to ruin anything.
thanx guys
/ mowing in high gear #2
First of all congratulation on your B2410 purchase/w3tcompact/icons/smile.gif
My answer would be feel out the speed in which does a better job cutting also keep your rpm where need be.
I rather use low range,but than again most of my mowing on a slope.[smile
Be careful and just take your time and have fun./w3tcompact/icons/wink.gif
Stay safe and be /w3tcompact/icons/cool.gif
Thomas..NH
/ mowing in high gear #3
Did you ask the dealer why he said to not mow in high gear? I don't know the speed ranges of the different gears on the 2410, and usually mid-range is fast enough to suit me on my B2710, but yes, I occasionally use high range when I want to go a little faster. And when I had the B7100, I did most of the brush hog mowing in high range.
Bird
/ mowing in high gear #4
I doubt that tractor companies design a range into their machines the only purpose of which is to travel to and from the job, which is what I also have heard some dealers say.
If you mow at too fast a speed, the sky will not fall; you will simply get a lousy cut. You cant mow as fast in high grass as low grass for the same quality cut.
I mow as fast as possible-almost always in high range-consistent with getting a good cut. If you are on flat land and mow frequently, you can go pretty darned fast.
Glenn
/ mowing in high gear #5
kokopelli2,
Again, congratulations on your new tractor. I believe when you say you have a "b2410 hts" you are indicating that you have a B2410 hydrostat which has a HIGH range and a LOW range (no MID-range), and if I understand you question correctly, you are asking "Is it okay to mow with the transmission in HIGH range?".
"Speed over the ground" does affect the quality of the cut. I see no problem mowing in HIGH range on reasonably level ground with minor grades as long as you are not straining the engine. You can easily adjust the ground speed as needed (or desired) with the hydrostat control pedal to achieve that quality of cut that you desire.
Kelvin
/ mowing in high gear #6
Are you doing finish mowing or field mowing? I do field mowing with my B2400 HSD and use low-range, but only because the area I cut is very hilly and rough and low-range gives more precise control over speed (or slowness and in this case). My choice has nothing to do with power. The flatter areas I mow in high range with no problem.
guys
thanx for all of the input. i am finish mowing on almost completely flat land. i had a b7300 for a day and it seemed to stuggle even in low gear. i have been going all out in low with the b2410 with out and RPM loss.
i have been overly please with my new pruchase. it is such an upgrade from my '71 JD 140!
/ mowing in high gear #8
kokopelli2,
I own a NH TC18 Hydro and mow with a 3 pt. 5' finish mower.
My tractor has a high range and low range only. I have always mowed the lawn in high range at a reasonable ground speed and NEVER had a problem with power or cut.
When I recently purchased a 4' rotary cutter, since I was mowing my field for the first time, I mowed in low range at full speed most of the time. My field is long and narrow (265' wide) and has a slight grade for about 1/4 of the length. I had NO problems mowing 2'-4' tall grasses, wild flowers and some small bushes.
Just listen carefully to your engine and keep an eye on your rpm.
Good Luck, JimBinMI
We boys and our toys!
/ mowing in high gear #9
JimBinMI, It would be my luck to be mowing all 2' grass and find a hole (with 4') grass growing in it if I mowed 'fast' the first time through! What a surprise that would be!
/ mowing in high gear #10
I agree with JimBinMi. I mow in high range unless the ground is too dangerous to be in high, and never see the rpm's drop one iota even in 3 foot high grass. Your 2410 has more horses than my B1700, so clearly if I can mow in high so can you I would think.
/ mowing in high gear #11
scruffy,
Used to have a great "farmer" neighbor down the road that owned about 60 acres. He had two old tractors with rotary cutters so I asked him if he had a chance, would he cut down my field and I'd pay him whatever he thought it was worth...he was a great guy that I trusted. Came home from work one day and he was back there cutting away, when he was done, he wouldn't take a dime...I did catch a smile on his face as he was cutting! /w3tcompact/icons/smile.gif Lost a great neighbor when he and his wife divided up their acreage into 6 lots, auctioned it off and moved to Tennessee. /w3tcompact/icons/frown.gif
So the field had been cut before, I had walked it, driven quad, snowmobile, bikes, tractor through it. Even had a previous neighbor that cut it and baled it to try to feed to his horses, they wouldn't eat it!
Anyway, I pretty much knew the field and full blast in low range is 3.87 mph on the TC18 hydro. I did slow down when I came to really thick stuff that I couldn't see through though! /w3tcompact/icons/laugh.gif
JimBinMI
/ mowing in high gear #12
The only limiting factor I find in mowing speed is how much I'm willing to bounce around and how clean the cut is. When mowing 3ft fields of hay/brush the cut gets a little sloppy if you go too fast since the balde can only cut so much and the faster you go the less time the grass is actually in contact with the blade. I can bog the engine down if mulching some really tall stuff and you try and go too fast but it's so obvious when you do that you just slow down a little! /w3tcompact/icons/smile.gif
/ mowing in high gear #13
I bought a B2400HSD from Carver in June and it is a mowing animal. I mow approximately 5.5 acres weekly and with the wet, cool summer we have had in Iowa the grass has grown like crazy. I have mowed 70 hours of grass this summer and about 95.5% has been with the transmission in the high speed range. I only change it to low for mowing when I am going straight up a severe hill. Most of my acreage is hilly but only one area requires the low range in the transmission. By the way, I use the 60 inch belly mower. This little thing is amazing. It just plain eats grass.
2002 Chevrolet C7500 MTI 805B-47 47ft Bucket Truck (A64194)
2002 Chevrolet...
Wilbeck 2109 12ft. Digger Disc Chisel (A65640)
Wilbeck 2109 12ft...
New/Unused Quick Attach Pallet Fork Frame (A65583)
New/Unused Quick...
New/Unused AGT Industrial SDA-140W Mini Wheel Loader (A65579)
New/Unused AGT...
2018 Ford E-450 Shuttle Bus (A61573)
2018 Ford E-450...
New Holland 499 MoCo (A66408)
New Holland 499...
