Mowing mowing in 2 or 4wd?
   / mowing in 2 or 4wd? #11
I mow in 2wd 90% of the time. There area couple slopes that are 18-20 deg and 4wd keeps the tractor straight.
I leave the FEL on but take the bucket off most of the time. If the ground is wet/damp and the grass needs mowed the FEL comes off.
   / mowing in 2 or 4wd? #12
I always mow in 2WD. 4WD is too hard for my lawn. I could use the 4WD from time to time when I'm going to get stuck in a ditch but that's all and I switch to 2WD right after.
I use 4WD for FEL work, 3PH implement, in winter or when I move in a wood but never for mowing.
   / mowing in 2 or 4wd? #13
4wd, not sure why you'd need it to mow. I was mowing along a snowmobile trail in 8" grass in 2wd low with no issues.
2015 Ford Transit Cargo Van (A54814)
2015 Ford Transit...
flooring (A55758)
flooring (A55758)
19008 (A56859)
19008 (A56859)
UNUSED FUTURE FT-FB30 HYD FELLER BUNCHER (A52706)
UNUSED FUTURE...
1995 NEWTON CROUCH PULL SPREADER (A58375)
1995 NEWTON CROUCH...
2021 Delta Manufacturing 30ft 10-Ton T/A Gooseneck Flatbed Equipment Trailer (A55851)
2021 Delta...
