Mowing efficency with a rotary mower
   / Mowing efficency with a rotary mower
This thread reflects what happens when you sit on a tractor all day with a repetitive job to do. The mind starts to wander and thoughts tend to "How can this task be done easier/quicker/better/more efficiently".
Probably many inventions and implement modifications have come from that situation.
But heck, if you are having fun doing the job maybe you don't want it to be over in a hurry. :laughing: :laughing:
Ha, truer words were never spoken:drink:. It always amazes me the cool stuff I can think up while riding the tractor.
It seems that there is a lot of factors that affect efficiency. Quite a few that I had not thought of (hence why I started this thread). Ultimately, it comes down to putting the most money into my pocket on any given job.
Tim
As I am reading through you guys replies, I am pondering what I could have done to make this mowing job more efficient. For much of the job, I was using the 270deg turn method on the corners. I am fairly certain this not the most efficient method. Maybe a modified zamboni pattern would have been better. I spent some extra time dodging small mesquites that I will grub out later rather than mow down. Human factors played a role (not sure what I could have done differently there except not drinking as much coffee before mowing. Getting old is tough on the body). I have a 7' wide mower and I try to overlap about 1 rear tire width (1.5').
I am pretty sure that a wider mower would be more efficient. I have been toying with buying a 12' flex wing. According to my calculations, the 12' mower is more cost effective ( not including the initial expense) on mowing jobs of about 20 acres or more (compared to my 7' mower). It's that $10,000 hit on the front end that keeps me from going for it. Plus most of my mowing jobs to date have been 10 acres or less.
Steve, I think that mowing calculator is what prompted me to develop my own mowing calculator. As I said I started out with a 90% efficiency factor. You are entirely correct, 90% or better is way optimistic. I am going to pay more attention to how I approach a mowing job in the future and try to be as efficient as possible. I will also track the efficiency of each job (it's pretty easy to do). It will be interesting to see how much improvement I can make.
regards,
Tim
   / Mowing efficency with a rotary mower #15
sorry if I missed it, but I always go much slower on the first mow than later after I know where things are..
   / Mowing efficency with a rotary mower #16
Tim,
Here's a simple formula that would provide an estimate of the acreage (Q*) you have to mow each year to have total costs (variable and fixed) be equal for the 7' and 12' cutters.
Let FC[SUB]12[/SUB] and FC[SUB]7[/SUB] represent the annual fixed costs ($/year) of the 12' and 7' option, respectively. The fixed costs include depreciation, interest on your investment, insurance, property taxes, etc. FC[SUB]12[/SUB] should be higher than FC[SUB]7[/SUB].
Let AVC[SUB]12[/SUB] and AVC[SUB]7[/SUB] represent the average variable costs ($/acre) of operating the 12' and 7' mowers, respectively. These variable costs include fuel, allowance for repairs and maintenance, and your labor rate. AVC[SUB]12[/SUB] should be lower than AVC[SUB]7[/SUB].
Calculate Q* = (FC[SUB]12[/SUB] - FC[SUB]7[/SUB])/(AVC[SUB]7[/SUB]-AVC[SUB]12[/SUB]).
If you expect to mow more than Q*, it pays to go with the 12' mower. If you expect to mow less that Q*, it pays to stay with the 7' mower.
Steve
   / Mowing efficency with a rotary mower #17
See http://www.extension.iastate.edu/Publications/PM696.pdf for a discussion of theoretical field capacity, measured in acres/hour, and computed as implement width (ft) * ground speed (MPH)/8.25.
Effective field capacity is computed as the theoretical field capacity * field efficiency (%).
The field efficiency is less than 100% because of the time spent turning, overlapping, etc.
I doubt whether the field efficiencies would differ much between the various implements, but the ground speeds may well differ.
The time of day, etc. may affect ground speed, but I speculate they would not have much effect on field efficiency.
Steve
Thanks for providing the link.
An interesting calculation Steve. Thanks for sharing. It clearly shows that I should be using a 12' mower. Now if only I can convince SWMBO.
Tim
   / Mowing efficency with a rotary mower #19
Tim
I was going to point out that there is a size of mower to size of area being mowed that is important to consider. EG a very large mower on a very small property is fairly inefficient with all the time that is taken up going back and picking up small areas that were missed while at the same time re-mowing areas you already covered. conversely a very small mower on a very large property you have inefficiency associated with overlap etc that builds up very quickly.
I wouldnt know how to do the calculation but someone out there im shure has. and it sounds like the above equation is close to what im talking about.
   / Mowing efficency with a rotary mower #20
Tim
I prefer to call 'em SWRUC.. She Who Remains Un-Convinced..:laughing:
I actually don't think mine is like that, she thinks we should buy a backhoe attachment sooner rather than later. Go figure. I'm leaning toward an actual backhoe, but take what you can get, right?
Sean
Miller Bobcat Welder/Generator AC/DC Welder, 1 Phase & 3 Phase Generator, S/N M0321574R, Kohler Gas (A59076)
Miller Bobcat...
UNUSED ELK AR500 3/8" STEEL SHOOTING TARGET (A58376)
UNUSED ELK AR500...
2007 Hummer H3 4X4 SUV (A56859)
2007 Hummer H3 4X4...
Kubota SVL 75-2 (A55272)
Kubota SVL 75-2...
UNUSED JCT 2 PRONG BALE SPEAR (A58376)
UNUSED JCT 2 PRONG...
2015 GENIE S-45 TELESCOPIC BOOM LIFT (A52709)
2015 GENIE S-45...
