Mowers
/ Mowers #1
presnewt
Thomson, Ga
Steiner 440,Kubota MX5400 HST cab
What are the advantages of the side discharge versus rear discharge mowers? Also, are ventrac mowers better, same or worse than steiner mowers? FYI I use a steiner 440 with steiner rough cut mower and a ventrac power rake. I am considering adding a finishing mower.
/ Mowers #2
Having had a Steiner side discharge mower and it was the worst of the three. it dug in on the roller mount where slopes changed and bounced due to the hard wheels in the front. it did have a better side discharge than the older Ventrac mower. The old model ventrac side discharge mower was better but scalped a little or left different level cut on rolling ground. The new Ventrac side discharge deck is the best I saw very uniform cut, no scalping, stays cleaner under the deck and no heavy unloading in in wet high grass. It makes a lot of air flow and it is a dream to service with the new hydraulic tilt. The downside was the counter bore for grease fittings on the new spindles is too small to tighten the loose fittings I found and had
to grind a socket down a little to lit them go deep enough into the counter bore to tighten them. I also had issues with grease fittings falling out of the roller bearings but the zerk fittings threads were undersized replaced with American fittings of the proper size ended that........ Jim
/ Mowers #3
Rear discharge mowers tend to send more chaff and dust back to the operator and also into the radiator screen. But, the rear discharge decks are not fitted with those huge side shoots that make manuevering more tedious.
/ Mowers
Can anyone give me a ballpark price for a ventrac 72 inch side discharge mower?
/ Mowers #5
Rear discharge normally discharge is larger clippings that a side cutter. Rough cut mowers are rear discharge and a friend who says problem with rear discharge finish mower is it will discharge much like rough cut, it cuts it and throws it out. What a side discharge does a certain amount of mulching as it cuts.
/ Mowers #6
The new one is $4k, the model before was $3.3k. Could maybe find a used older model for $2-2.5k but these attachments are near impossible to find on the used market.
/ Mowers #7
Simply remove the side chute, end of story...... Jim
/ Mowers #8
I have the Ventrac Model MC600 60-inch rear-discharge deck, to which my dealer attached the Ventrac No, 70.8088 mulching kit prior to delivery. This is my third year using this deck.
I have never run the deck without the mulching kit installed, and I have never used the comparably sized Ventrac side-discharge mower deck. So, I have had no way to compare the size of the clippings ejected by the side-discharge deck to the size of the clippings ejected by my rear-discharge deck.
That said, I can tell you that the clippings ejected by my rear-discharge deck are pretty small. I use the deck not only to cut grass during the growing season but also to shred leaves in the Fall. (Our property is heavily wooded, mostly with oaks, so we get a lot of leaves in the Fall.) The leaf shreds are much smaller than the original leaves themselves. The size of the shreds depends somewhat on the types of leaves and how dry they are.
I have not had a huge problem with material clogging up the particulate screen that sits behind the radiator. In fact, the bar-graph temperature display on the instrument cluster has never gone above the second bar. Most of the time, when I am mowing, only the first bar glows, and even that bar will extinguish pretty quickly after I disengage the PTO and idle the engine prior to shutting the engine off.
How much material will build up on the particulate screen seems to depend most heavily upon how dry the grass or leaves are when I am mowing or shredding.
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60352)
2019 International...
1996 Ford E-450 Shuttle Bus (A61573)
1996 Ford E-450...
2025 Pabreak 80in. Bucket Skid Steer Attachment (A61567)
2025 Pabreak 80in...
3ft. 5-Point Metal Star (A61574)
3ft. 5-Point Metal...
2016 FREIGHTLINER CASCADIA  125 6X4 T/A  DAY CAB TRUCK TRACTOR (A59914)
2016 FREIGHTLINER...
2014 John Deere 350G Hydraulic Excavator (A64194)
2014 John Deere...
