Mowing Mowers for B7610
   / Mowers for B7610
You will be much better off with a small rear or front mount Caroni flailmower from Agrisupply for your 7610 as they are much less work and are much safer in operation than belly mower or three point hitch finish mower.
They have a continous internet sales special and the frieght is included int eh price we have well over one hundred pages discussing flailmowers and their use here on the forum if you would like to look at them.
A flail mower is much safer in operation around 2 and 4 legged rug rats and other pedestrians as the entire cutting operation is contained within the flail mower hood and the grass is thrown to the rear with the rear mounted units.
I had viewed flail mowers as more like brush cutters and for really tall grass. What i would be needing is a finish (not finnish) mower to change the grass from say 5" to 3" like my lawnmower does.
/edit - what's the biggest flail or finish mower I could haul? 7610 has 18 pto 23 engine hp.
and about how fast on flat like a table, unobstructed lawn?
   / Mowers for B7610 #12
Mowing speed depends on the ground conditions and the grass hieght, I move along with our motorised unit at 3-5 miles an hour on good turf and don't have to worry about scalping or missing with grass strips as I always mow in a spiral AND mowing in a spiral takes less time BECAUSE you are not stopping to turn around and backing up to realign the mowers pattern and you use less fuel and the grass looks beautiful with no stress issues.
You just have to go back and run over the circle of uncut grass that is the center of the spiral and it still looks great. No stomping the left or right brake pedal on yours as the wheel and roller may tear the sod if you are not driving slowly.
No, the flail mower is used for turf grass as well with no issues at all.
The Caroni 47 inch flail mower with the finish mower rotor (four rows of grass slicers) will work well for your tractors power as the rotor is passive and delivering massive torque via the belt drive
The flail mowers rotor speed is what determines how well it slices turf; if you travel too fast it will cut poor and the same applies to a belly mower or rear finsh mower
About mowing speeds-
Its not the issue with ground speed that you need to worry about-
You must maintain the 540 RPM engine speed setting to deliver the proper torque to operate the finish mower rotor or any flail mower rotor at the proper rotor rotation speed to mow with it.
The more you mow to achieve the final turf grass blade hieght you want,
the less work is required to mow with a flail mower and the turf is stressed less as well.
The same applies with a missed mowing-as the slower you travel the better the finish.
Mowing in a spiral works very well and the turf still looks great two weeks later in my case.
The flail mowers rear roller is used as the hieght adjustment and has several hieght positions, the skids in front of the rear roller prevent the mower from scalping the turf and allow you to leave the mower upright when it disconnected from the tractor.
Changing knives on a flail mower is much easier than dealing with a belly mower as you simply unbolt the knive and flip it over to the opposite cutting edge if it needs a new cutting edge or replace it if it is broken.
The only real cleaning you have to do with a flail mower is the dry built up grass on the gear box and flat weldments in front and occasionally clearing the rear roller if you have no scraper on the rear roller.
   / Mowers for B7610 #13
Sounds to me like the perfect time to negotiate with "Gram" for a second tractor with full time mowing assignments!!
Funny thing about mounting/dismounting the MMM is everytime I say to myself "this should only take a second" and then every time for a different reason it doesn't go smoothly and ends up taking 15 minutes or so. Sometimes the shaft doesn't want to line up or the 3PT hitch pins don't want to drop down without some encouragement from a hammer and wood or a pin gets stuck etc.
Maybe a big BX is your future.;)
   / Mowers for B7610 #14
Why do that when he can have a 4 foot Caroni flail with a finish cut rotor for
$1,731.95 delivered to his door with the internet sales price or 1,499.95+tax
at one of their stores.
2016 Chevy Tahoe (A56859)
2016 Chevy Tahoe...
2004 FREIGHTLINER CL120 TANDEM AXLE DAY CAB (A57880)
2004 FREIGHTLINER...
2014 Dodge Charger Sedan (A55973)
2014 Dodge Charger...
2025 SDLANCH SDLE20 MINI EXCAVATOR (A58214)
2025 SDLANCH...
2018 Nissan Pathfinder SUV (A56859)
2018 Nissan...
2022 JOHN DEERE 624P WHEEL LOADER (A52709)
2022 JOHN DEERE...
