Mower Spindles - 48C
/ Mower Spindles - 48C #1
topsaiilbye
Ottawa, Ontario, Canada
John Deere 325
about to change belts over the winter months. currently working ok. 500 hrs. Should I be changing spindles? what should I be looking for?
Wayde
/ Mower Spindles - 48C #2
I had to replace my spindle bearings sooner than 500hrs (the bearings were obviously shot). It was an easy job. Remove spindles, remove retaining clips, press bearings out, replace. The bearings are cheap on Amazon. If you're going to have it apart it wouldn't hurt to change them.
/ Mower Spindles - 48C #3
We have 525 hours on a 62c deck with no spindle problems. Last winter I lubed the idler pulley bearings with a needle grease gun adapter by carefully sneaking past the seals. The deck is slightly quieter too.
/ Mower Spindles - 48C #4
I remove the belt and give things a roll to see if they run smooth, check the tensioner as well. You're likely fine.
2019 GMC Canyon SLE 4X4 (A62679)
2019 GMC Canyon...
2015 VANTAGE TRAILER 3 POD PNEUMATIC TRAILER (A63569)
2015 VANTAGE...
2025 Hydraulic IRANCH Tilt Bucket Mini Excavator Attachment (A64553)
2025 Hydraulic...
2025 Swict 84in. Bucket Skid Steer Attachment (A64553)
2025 Swict 84in...
2010 Transcraft 35ft. Tri-Axle Aluminum End Dump Trailer (A64556)
2010 Transcraft...
2201SFL (A64553)
2201SFL (A64553)
