Rotary Cutter mower seal 80 40 10 and should I put grease in the gear box
   / mower seal 80 40 10 and should I put grease in the gear box #1
case310350
Seal is leaking from the shaft on the gear box. the seal is 80 40 10, cant seem to find one online. Also I have read from past posts that putting grease in the gear box is one way to fix the leak, but they didn't say what kind of grease.
Also whats the best grease to use on the spindle bearings.
thanks
   / mower seal 80 40 10 and should I put grease in the gear box #2
The thinnest grease you can get an there & not leak out. I used a pourable grease & some 90wt gear oil in my flail mower gearbox. Others use whatever is in their grease gun.
Oil would be better, but I bet 95% of the time grease won't shorten the lifespan of an old gearbox in the long run.
   / mower seal 80 40 10 and should I put grease in the gear box #3
We use a flow able grease that is called double aught or 00 grease. I think tractor supply carries it. It comes in a squeezable quart bottle like 90 wt oil.
2019 JLG ECOLIFT 70 SELF PROPELLED MANLIFT (A51242)
2019 JLG ECOLIFT...
ECHO SRM-2210 GAS POWERED WEED EATER (A51244)
ECHO SRM-2210 GAS...
HAMM 3205 SMOOTH DRUM ROLLER (A51242)
HAMM 3205 SMOOTH...
2016 Volvo 82041 9.5 Cu Yd Hydraulic Loader Bucket (A50322)
2016 Volvo 82041...
Case SV 340 Skid Steer Loader (A52349)
Case SV 340 Skid...
