Rotary Cutter mower seal 80 40 10 and should I put grease in the gear box
   / mower seal 80 40 10 and should I put grease in the gear box #1
case310350
Bronze Member
Seal is leaking from the shaft on the gear box. the seal is 80 40 10, cant seem to find one online. Also I have read from past posts that putting grease in the gear box is one way to fix the leak, but they didn't say what kind of grease.
Also whats the best grease to use on the spindle bearings.
thanks
   / mower seal 80 40 10 and should I put grease in the gear box #2
The thinnest grease you can get an there & not leak out. I used a pourable grease & some 90wt gear oil in my flail mower gearbox. Others use whatever is in their grease gun.
Oil would be better, but I bet 95% of the time grease won't shorten the lifespan of an old gearbox in the long run.
   / mower seal 80 40 10 and should I put grease in the gear box #3
We use a flow able grease that is called double aught or 00 grease. I think tractor supply carries it. It comes in a squeezable quart bottle like 90 wt oil.
2000 INTERNATIONAL 4700 - 4X2 GARBAGE HAULER TRUCK (A51243)
2000 INTERNATIONAL...
2015 CATERPILLAR 573C FELLER BUNCHER (A51242)
2015 CATERPILLAR...
PORTER CABLE 150 PSI AIR COMPRESSOR (A50854)
PORTER CABLE 150...
(4) Texas Built 25' Stand Alone Panels (A50515)
(4) Texas Built...
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A52128)
Neckover GL24-2-7K...
2008 INGERSOLL RAND DD-16 SMOOTH DBL DRUM ROLLER (A51242)
2008 INGERSOLL...
