Mowing Mower + Rock = $
   / Mower + Rock = $
Thanks for the feedback. With 6 acres, sometimes you miss one. I removed the offending rock yesterday - the tip belonged to 4ft diameter 400lb drumlin granite bolder.
I'll ditch the fried blade, and get a set that I can have a couple of spares. Thanks for the advice.
   / Mower + Rock = $ #12
On the John Deere parts website right now there is a printable coupon good for 20% off mower blades. It's good through May 26th.
   / Mower + Rock = $ #13
Bird; That is good info. I can expect to have a powder topsoil surface ( without large rocks ) in another 30 years. I will mark it on the calander.
   / Mower + Rock = $ #14
Can you post a link to the 20% off coupon?
Thanks,
D.
   / Mower + Rock = $ #16
While you have the blade off, you may want to check the cast aluminum hub where the lower bearing is. I have seen several cracked housings from less of a hit.
UNUSED WOLVERINE MAD-12-12D HYD AUGER DRIVE & BIT (A57193)
UNUSED WOLVERINE...
UNUSED FUTURE SE61-61" HYD SWEEPER (A57193)
UNUSED FUTURE...
PALLET OF SPRING LOADED MUD FLAP HANGERS (A57192)
PALLET OF SPRING...
Bobcat T590 (A53317)
2017 Ford F-350 Ext. Cab Pickup Truck (A56858)
2017 Ford F-350...
Year: 2016 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A55853)
Year: 2016 Make...
