Oil & Fuel Mower oil issue
   / Mower oil issue #1
PioneerMan
So after sitting for the season my 6ft flail mower had milky oil. Drained it. Could I have just burned it off? Replaced with hydro transmission oil cause I am really low on oils right now. Ran it for a few minutes with the plan on draining it for something better, just wanted to get all the moisture out. A little wasteful, I know. Did I do the wrong thing? What should I put back in, or would that work? I am thinking the stuff in there is a little heavy. ?
   / Mower oil issue #2
What's the owners manual call for? Most of these type gearboxes use a GL-5 gear oil SAE 80W90 or 80W140, etc. The water gets in there from condensation( assuming you have the fill plug screwed on and the seals are good). It can vaporize off if used for long periods of time where the oil gets hot but it will come back if it's sits for a long period of time.
   / Mower oil issue #3
The milk is alot of water where water does not belong. Change it and make sure your vent is not taking in rain water.:thumbsup:
2017 Terex Warrior 1800 Screener (A50322)
2017 Terex Warrior...
HYSTER 60FT WAREHOUSE FORKLIFT (A51242)
HYSTER 60FT...
2013 Cadillac ATS Sedan (A50324)
2013 Cadillac ATS...
Bush Hog 84in Rotary Cutter (A50322)
Bush Hog 84in...
2011 Ram 1500 4x4 Crew Cab Pickup Truck (A50323)
2011 Ram 1500 4x4...
