Mowing mower lift cylinder lockout valve
   / mower lift cylinder lockout valve #1
cmkh3
Kitsap County, Washington
John Deere 322
Enlightenment please /forums/images/graemlins/confused.gif
I will soon have a 318 with 4 hydraulic ports up front currently attached to the front blade. One set is used for the angling and the MMM up/down action so my questions are;
Does this work by providing a bypass in the hydraulics or ? How hard is it to install and what are the chances of getting air in the line?
Chris
   / mower lift cylinder lockout valve #2
Chris, if your 318 has both a snow plow and a MMM it should have a lock-out valve installed on the tractor. To check if your tractor has one take a look under the back of the tractor on the left side at the rockshaft cylinder, you should see a small brass valve threaded into the cylinder.
If you do not have one they are easy to install and I believe the JD P/N is AM39556. It should be kept closed when using the left front hydraulic outlets and open to use the rockshaft cylinder. Hope this helps.
Ken /forums/images/graemlins/smile.gif
Thanks Ken,
I will look for it tomorrow. HMMM is there another valve for the rear up/down as it seems to be on the same circuit as the front blade?
Chris
2004 TRAVIS 48' WALKING FLOOR REFUSE TRAILER (A53426)
2004 TRAVIS 48'...
2025 New/Unused LandHonor Massage Chair Sofa (A51573)
2025 New/Unused...
2022 MGT CM11CUFT S/A Towable Concrete Mixer (A51691)
2022 MGT CM11CUFT...
2015 KENWORTH T370 QUINT AXLE DUMP TRUCK (A52576)
2015 KENWORTH T370...
NEW Wolverine Skid Steer Drive and Augers (A53002)
NEW Wolverine Skid...
2011 DOOSAN ALL TERRAIN FORKLIFT (A52576)
2011 DOOSAN ALL...
