Mowing mower lift cylinder lockout valve
   / mower lift cylinder lockout valve #1
cmkh3
Kitsap County, Washington
John Deere 322
Enlightenment please /forums/images/graemlins/confused.gif
I will soon have a 318 with 4 hydraulic ports up front currently attached to the front blade. One set is used for the angling and the MMM up/down action so my questions are;
Does this work by providing a bypass in the hydraulics or ? How hard is it to install and what are the chances of getting air in the line?
Chris
   / mower lift cylinder lockout valve #2
Chris, if your 318 has both a snow plow and a MMM it should have a lock-out valve installed on the tractor. To check if your tractor has one take a look under the back of the tractor on the left side at the rockshaft cylinder, you should see a small brass valve threaded into the cylinder.
If you do not have one they are easy to install and I believe the JD P/N is AM39556. It should be kept closed when using the left front hydraulic outlets and open to use the rockshaft cylinder. Hope this helps.
Ken /forums/images/graemlins/smile.gif
Thanks Ken,
I will look for it tomorrow. HMMM is there another valve for the rear up/down as it seems to be on the same circuit as the front blade?
Chris
2016 Toro Pro Force Towable Blower (A50324)
2016 Toro Pro...
BUSH WACKER ST-180 ELITE BATWING ROTARY MOWER (A51406)
BUSH WACKER ST-180...
2019 PETERBILT 567 TRI-AXLE MID-ROOF SLEEPER (A52472)
2019 PETERBILT 567...
New Long Forks (A53002)
New Long Forks...
2015 FREIGHTLINER SPRINTER VAN (A52576)
2015 FREIGHTLINER...
GENIE MAN LIFT (A52472)
GENIE MAN LIFT...
