I understand, JimBinMI, but if you adjust your top link all the way out just as long as it will go, then pick up the mower as high as the 3-point will lift it, will the mower be level or will the back end still be tilted up? And in that position, will the lowest part of the mower be 16" to 20" off the ground (like Wen is talking about)? I doubt it. Now if you had side rails that were only 3" to 5" high, you might be all right, but with the more common, higher side rails, I think you'll have a bit of a problem; not insurmountable, of course. All things are possible; given enough time and money./w3tcompact/icons/smile.gif
Bird
