Mower for B7100
/ Mower for B7100 #1
ojaikubota
We have an old B7100 4WD with a B219 Loader and we want a mower for it, preferably one of the rear mowers. Can any advise what mower we should get or where to find a used one?
Thanks!
/ Mower for B7100 #2
I have the same tractor and loader combination that you do. I use a 60" Land Pride finish mower mounted on the 3 point hitch. It works great. I cut a field with about 4 acres 4 or 5 times a summer.
/ Mower for B7100 #3
I have the same tractor and run a 48" rough cut mower. Works fine unless the grass is 2'-3' tall and thick, then you have to make lots of small passes.
I found mine used on Craigslist.
/ Mower for B7100 #4
I have the same tractor but with a 60" belly mower. I'm thinking I'd like a rear mount mower a little better, something that would lift higher to tool around our place without dragging all the time, and something easier to put on/take off. Also looking at getting a rear discharge mower at the same time.
I'm wondering if I go to a rear discharge if it would pull enough easier that I could go to a 72" mower...
/ Mower for B7100 #5
I used to have a 1995 B7100 with a B1630C loader and I used a 48" Bush Hog Squealer regularly with it; worked just fine. But I never had a finish mower for that tractor.
Wolverine Brush Cutter BC-13-72W Skid Steer Mount  (A62679)
Wolverine Brush...
Easy Lawn Hydro Seeder (A65579)
Easy Lawn Hydro...
2009 VOLVO VHD BOBTAIL VACUUM TRUCK (A63569)
2009 VOLVO VHD...
Two (2) John Deere 5000-Series Tractor Grill Guards (A65640)
Two (2) John Deere...
2015 Ford F-150 Pickup Truck (A64556)
2015 Ford F-150...
Teakwood Wagon Wheel Bench (A65583)
Teakwood Wagon...
