Rotary Cutter mower driveshaft shields chained or unchained
   / mower driveshaft shields chained or unchained
Just don't go near it, don't even get off(or out) of the tractor with the pto engaged no matter what implement is in use. My tractor has an alarm that will damage your hearing if you open the cab door with the pto engaged.
Thanks for the input, Gary
   / mower driveshaft shields chained or unchained #12
With some implements you have to get off the tractor while the pto is engaged. Two that come to mind are chippers and logging winches.
You're right, I was exaggerating a bit. But if you HAVE to work near a spinning shaft, and there are safety devices available, then by all means, use them. I don't use chippers or winches, but I do use a post hole digger. However I really don't have to get off the tractor with it engaged, and I don't use it very often.
Thanks for all the input guys,,, Gary
2015 John Deere 310SL (A47384)
2015 John Deere...
2019 KEESTRACK K6 SCALPING SCREENER (A51242)
2019 KEESTRACK K6...
2015 Acura MDX SUV (A50324)
2015 Acura MDX SUV...
2020 ASV VT70HO Skidloader (RIDE AND DRIVE) (A50774)
2020 ASV VT70HO...
2018 John Deere 60G Excavator (A50490)
2018 John Deere...
