Mower deck won't lower
/ Mower deck won't lower #1
pridurak
John Deere LT180
New member here with a used John Deere LT180. My mower deck lowers by a lever to start cutting the grass.
I was using my mower and everything was fine. But now even when I engage the lever the deck won't go down. Also a rubber belt sticks out from underneath the deck. I can't tell if it simply came off the track or something broke. Suggestions before I call someone to repair it?
/ Mower deck won't lower #2
Maybe take a picture or two and post it so folks can see what you are describing.​
/ Mower deck won't lower #3
The LT180 deck does NOT raise/lower with a lever: the lift is controled by a foot peddle with the operator's left foot. It can be locked in the "Raised" position with a green plastic handle, located just below the Choke. If the deck is locked in the "raised" position: depress the left foot peddle, push down on the green handle then slowly release the foot peddle to lower the deck.
The yellow lever on the right, just below the steering wheel just engages/releases the blade clutch.
If a belt is litterally sticking out, then that must be addressed before engaging the blades. A photo might help???
2007 FREIGHTLINER M2 106 4X2 26FT BOX TRUCK (A59912)
2007 FREIGHTLINER...
1994 Chevrolet C70 Kodiak 18FT Box Truck (A61573)
1994 Chevrolet C70...
ATTENTION! PLEASE READ (A64119)
ATTENTION! PLEASE...
2025 BrushFox XHD72 72in Rotary Brush Cutter Skid Steer Attachment (A61572)
2025 BrushFox...
EZ-GO SHUTTLE 2X2 TXT GAS GOLF CART (A63276)
EZ-GO SHUTTLE 2X2...
2011 Ford F-250 RKI Service Truck (A61573)
2011 Ford F-250...
