Mower deck wheels and bracket on JD 318
   / Mower deck wheels and bracket on JD 318 #1
masher
Michigan
John Deere 318
I need to replace all the wheels and brackets on the deck of my 50" 318. I can find the wheels and bolts but I really need to replace the metal bracket that the wheels bolt through and adjust the height of the mower deck. They are just a small piece of steel with holes in it with a pin to attach it to the mower deck. Mine are wore out and the wheels won;t bolt to them correctly. Any idea where I can get replacements?
   / Mower deck wheels and bracket on JD 318 #2
Part not available through Deere? or looking for an alternative?
It looks like flat rolled steel that with some holes drilled will be like new.
I did just find them through Deere. Just wondering if there was any 'aftermarket'. Over $26 each at Deere! I need all 4 new.
Thanks
   / Mower deck wheels and bracket on JD 318 #4
That is high, but making them shouldn't be hard to do... unless no drill press available.
Thats a good idea. Never thought of doing that for some reason.
Thanks
Ford 1710 Tractor (AS IS) (A50774)
Ford 1710 Tractor...
2014 International Durastar 4300 Terex BT2047 47ft 10 Ton Crane Truck (A50323)
2014 International...
NEW Wolverine 72'' Skid Steer Tiller (A53002)
NEW Wolverine 72''...
Chemical Tank & Pump (A50121)
Chemical Tank &...
2015 Ford F-550 Godwin 184U Crew Cab Mason Dump Truck (A51692)
2015 Ford F-550...
2012 Ford F-450 XL (A50120)
2012 Ford F-450 XL...
