Mowing Mower deck washer
   / Mower deck washer #1
Gregs JD1023
Western Massachusetts
2011 John Deere 1023E
Has anyone used the hose connection on mower decks to clean out the deck? I have one on my 54" mid deck for my 1023e. I used it a couple of times to clean the deck but found it dripped green ooze all over my shed floor. :( I guess I could have run the deck for a while to help dry out the deck before parking in the shed. Seems like a waste of expensive fuel. Since I have a quick connect deck it's easy to take off & clean after every 4-5 mowings. I wonder about using water to clean and rust etc. Any thoughts?
   / Mower deck washer #2
the common thought on the hose attachment is a waste of time. I used mine once and didn't feel it did a good enough job to ever use it again
   / Mower deck washer #4
AND leaves a green oozing mess wherever you do the washing.
I like to keep the deck as dry as possible. Wash the topside a couple times a year, but use the air compressor after every mowing to blow off the tractor and the deck.
   / Mower deck washer #5
I tried out the hose connection once on a previous mower, but never on my current one. It just didn't work well enough to be worth the trouble. I, too, use the air-compressor on the mower and the string trimmer every time I use them. Of course I also use it on my power saws, drills, and even my electric razor and Wahl hair clippers every time they're used.:laughing:
   / Mower deck washer #6
Always used a leaf blower to clean the deck and tractor with. Usually just took the deck off in the shop and cleaned it underneath, then swept the mess up !
   / Mower deck washer #7
I found the only efficient way to make it work was to lower the deck completely down to maximize water spray with less air and at cutting speed. It would soften and then throw chunks out leaving a green pool to drive through. It was not much more work and less fuel and water to use the pressure washer. I do know a clean deck creates a better vacuum grass blade lift and a resulting better cut/mulch either way it is done.
   / Mower deck washer
Sounds to me that there is no excitement about these deck hose washers. Just a sales gimmick. Although I do have one on my Toro lawn mower and it works good on that. I think it's because of the small 20" deck size. I guess I'm done with using the one on my 54" deck. I just as soon take the deck off and clean it properly.
I also use a leaf blower to completely clean my tractor after mowing.
   / Mower deck washer #9
When I first purchased my tractor and deck I tried the hose connector cleaning device a few times with disappointing results... then I figured out the proper procedure.
Like Garybake stated, the deck needs to be resting on the ground, in my case a level asphalt driveway. I release the anti-scalp wheel latches and lower the deck flat onto the driveway, attach the hose, turn on the water and run the mower deck a few minutes at 2500 RPM. Lot's of gunk and green water falls out. I have visually inspected the underside of the deck after executing this procedure the past several cuts and it actually works pretty well. I do have a mulching kit installed, so I don't know if that makes a difference.
   / Mower deck washer #10
A leaf blower works for me too, I worry about what the water does to hot bearings.
2017 Ford Explorer AWD SUV (A50324)
2017 Ford Explorer...
2014 Infiniti QX60 SUV (A50324)
2014 Infiniti QX60...
2003 Maverick Pathfinder 2200V Center Console Fishing Boat with T/A Boat Trailer (A50324)
2003 Maverick...
2003 Doyle Semi Horse Trailer (TITLE) (A50774)
2003 Doyle Semi...
2006 Toyota Tundra 4X4 Pickup Truck (A50323)
2006 Toyota Tundra...
