Mowing Mower Deck vertical storage problem
   / Mower Deck vertical storage problem #1
Tdog
Platinum Member
SE Louisiana
BX22
Each winter I store my 60" mower deck on its side in order to save shop space - - it also allows me easier access to the blades. This year I noticed a pretty good size puddle of oil under the deck - - I assume that is from the gear box leaking. I thought I had the plug screwed in well, but maybe not? Anyone else have that problem?
I'll have to check to see what kind of oil it takes - - i hope I have it on hand. It's almost time to give it its 1st workout of 2010.
Jack
   / Mower Deck vertical storage problem #2
I've been stowing my deck vertically for years and haven't had a problem. You may have a loose or missing filler plug or a bad gasket.
   / Mower Deck vertical storage problem #3
I had the same leak the first winter, then tightened all nuts and added fluid. The second winter had no leaks.
   / Mower Deck vertical storage problem #4
Most gearboxed have a vent on top. Did the oil come from a vent?
   / Mower Deck vertical storage problem #5
80-90 gear oil is what it takes, if you were asking. Supposed to replace the gear oil at 50 hours.
   / Mower Deck vertical storage problem #6
never had a leak yet.. but my bota manual states the oil seals needs to be repalced every 2 years- not sure why .
   / Mower Deck vertical storage problem #7
You've not said what brand you have, but my Kubota RCK60B deck has not leaked....yet. I replaced the lube in mine with WalMart 75-90w synthetic.
   / Mower Deck vertical storage problem #8
My deck leaked out of the breather hole the first year I had it perpendicular to the floor. Since then I leaned it up against the wall slightly less than vertical and no leak. More than likely that is the origin of your leak.
2013 Chevrolet Traverse LS SUV (A50324)
2013 Chevrolet...
Wolverine Quick Attach Skid Steer Rock Rake (A50514)
Wolverine Quick...
KODIAK 10' HD ROTARY MOWER (A51406)
KODIAK 10' HD...
2014 CATERPILLAR 349FL EXCAVATOR (A51242)
2014 CATERPILLAR...
1998 JOHN DEERE 643G FELLER BUNCHER (A51242)
1998 JOHN DEERE...
2018 CATERPILLAR 305E2CR EXCAVATOR (A51242)
2018 CATERPILLAR...
