Mowing Mower Deck Stands
   / Mower Deck Stands #51
Thanks PeterK for taking the time and effort to post this. I don't store my MMM off the tractor so I hate to spend $100 on stands. But I'm getting too old and feeble to manhandle the mower when I take it off to service it,sharpen my blades, and clean the underneath.
Your solution would be perfect for me. Thanks again.
   / Mower Deck Stands #52
Why can't you just remove the vent nut and replace it wjth a non vented one for the winter??? Just hang the vented one on the drive shaft w/wire so you'll remember to replace it when it's time to mount the deck.
I was so surprised by this great idea that I raced outside to the garage to check the deck, only to be surprised and reminded that it is on the Bota at the moment...
   / Mower Deck Stands #53
I just finished the scheduled service on my MMM and used the stands I made from the instructions and example given by PeterK.
What a difference. Much better and easier with the MMM on a stand.
   / Mower Deck Stands #54
Materials list:
2- 3/4 x 12" hex bolts
4- 3/4" washers
2- 3/16 x 1 roll pins Lowe's
4 - hitch pins TSC
4- 4" plastic wheels for 3/4 axle McMaster
2- Cat 01 adapter sleeve from 3/4" id to 1" od TSC
The wheel on the left (in photo) is fixed with a washer and roll pin. The sleeve fits inside the mower anti-scalp mount and is secured through deck, sleeve and bolt using the Kubo pins. The right wheel is secured between two hitch pins. I used a wider wheel than others I've seen to make it more stable.
Do you have a part number for the wheels you used?
   / Mower Deck Stands #55
I just bought a set with the 5" wheels for my Kubota BX2200 60" mower deck. I have to say I'm very pleased with them. They arrived quickly, well packaged and I'm impressed with the quality. Took me less than 5 minutes to install them and get my deck safely stowed against he wall of my garage, freeing up a whole lot of space. Also, it will be much easier to work on the deck, remove and sharpen the blades, etc.
Thanks Larry, I am one satisfied customer.
regards
Paul
2013 Land Rover Range Rover Sport 4X4 SUV (A55853)
2013 Land Rover...
New Wolverine 72in Skid Steer Brush Cutter (A59000)
New Wolverine 72in...
Great Dane Van Trailer (A56435)
Great Dane Van...
SCAN TO RECEIVE TEXT UPDATES (A52709)
SCAN TO RECEIVE...
RING 2 STARTS HERE @ 9:15 AM (A58375)
RING 2 STARTS HERE...
2006 International 9400i (A55302)
2006 International...
