Mower Deck Removal with Shaft Drive
   / Mower Deck Removal with Shaft Drive #1
GTSRider
Cub Cadet 3000
I am having a heck of a time trying to figure out how to remove the mower
deck from my Series 3000 Cub Cadet with shaft drive.
I have all removed.... but deck does not move far enough rearward to
free shaft.
I could get it out if I removed rear wheels and suspended tractor.... but I know there is a trick to this.
Can anyone explain this puzzle to me ?
Thanks,
Pete
   / Mower Deck Removal with Shaft Drive #3
The PTO has a slip collar on it, so if you push back the bigger outside knurled ring, (slip collar) and pull the shaft off at the same time it will come out. It's a little tight under there while doing it, but the PTO shaft is extendable and can be unhooked in almost any position.
Good luck!
   / Mower Deck Removal with Shaft Drive #4
there is a quick connect collar on the end of the driveshaft that connects to the pto. compress the collar, and the driveshaft collabses on itself.
Thanks Guys.... this is just what I was looking for !
I was looking to slide shaft out..... barking up the wrong tree.
Now the job will be a cinch.
Pete
2001 VOLVO A35D WATER TRUCK (A51242)
2001 VOLVO A35D...
2017 JLG Skytrak 6036 6,000LB 4x4 Rough Terrain Telehandler (A50322)
2017 JLG Skytrak...
2013 Ford E350 Box Truck (A47384)
2013 Ford E350 Box...
2020 CATERPILLAR 326 EXCAVATOR (A51242)
2020 CATERPILLAR...
2000 CATERPILLAR 140H MOTOR GRADER (A51406)
2000 CATERPILLAR...
2021 Case IH Magnum 240AFS CVX Connect MFWD Tractor (A50657)
2021 Case IH...
