Mowing Mower deck mover
/ Mower deck mover #1
ironman
HELP! Guys, I'm trying to find the thread for the mower deck mover that is basically a couple of shafts with wheels on them that go in place of the scalp wheels on the front of the deck. Then, you turn the deck on its side and move it. Anybody know the name of the folks that make these things?
/ Mower deck mover #2
I went to Lowes and in the section with all the casters I bought some small "low boy" casters that the scalp wheels sit in...mine are brown with each having three little casters each on a metal frame cradle. They're good for some 150# a piece. Someday I'll take a picture and post it. I bought them for $7 each and, obviously, use 4 for the removal process.
With them I can remove the deck in about 4 minutes. With the small wheels, you're stuck removing the deck in the smooth-floor garage.
Not that this is the thread you were speaking of, but this is how I solved the problem of that heavy deck.
/ Mower deck mover #4
I got a set of those axles and I really like them. Can sharpen the blades very conveniently, plus it saves quite a bit of floor space with deck vertical in winter.
Remember winter?? :)
RDnT
/ Mower deck mover #5
I have a set of those moweraxles and they are the way to go for stowage and servicing of the MMM.
Use the FEL to lift the MMM into position then set it down. The MMM is easily rolled around out of the way.
/ Mower deck mover #6
I hope that deck gets some use.
Volfandt, what is that bungee I see in this photo?
/ Mower deck mover #7
That bungee is part of my feeble attempt to fabricate a mulch plug for the BX's 60" MMM. :D
I did a thread on it many moons ago.....
End result was that it did OK if I kept up with the grass which meant mowing at least 2 times a week. If it had to cut over a 1/2" it would make windrows and it was practically useless in damp/wet grass.
It was one of those winter projects that just didn't cut the musturd when put in use :D
Volfandt
/ Mower deck mover #8
Three things:
1) Dude. Didn't see the line in the manual about steam cleaning and waxing your mower after each use.
2) Where do you "pick" from to get the MMM up on those axles? I'm assuming there is some place you can hook in or some strap you made and that you don't just pick up one lip of that oh-so-pretty mower deck and hope it doesn't tip to the other side when you get it up...
3) While this is a nifty way to store the deck, it still looks like a royal pain to pull it out with the turning of the scalp wheels and replacement of the one set with these axle things. Turned the scalp wheels ONCE and vowed to never do it again. Took a half hour and wasn't very easy. Or fun.
/ Mower deck mover #9
Good question, I have the same, how do you guys rig the deck to pick it without scraping something or twisting something or otherwise damaging a $1,600 dollar lawn mower attachment?
/ Mower deck mover #10
> Dude. Didn't see the line in the manual about steam cleaning and waxing your mower after each use.< Oh it's there on page 'errr, ahhh, yeah, that page :D
Actually that pic was taken when that MMM was still a virgin and hadn't cut one single blade of grass yet. You see when one buys a brand new MMM in the dead of winter, one's mind starts to modify and change things after said mind has sat and looked at said MMM for too long :D
How did I lift it into that position? Easy, 1st you start off with FEL bucket hooks (did a thread on that), hook up a chain to the MMM and to the bucket hooks and then I let the BX's hydraulics make little work of depositing said 250lb MMM where ever I want it too :D
These pics were taken the following winter when I was putting the MMM away for the winter. It weren't as purty as it was in the 1st pic.
I can R&R my 60" MMM in about 10 - 15 minutes without breaking a sweat. it's all in having a plan :D
/ Mower deck mover #11
I hung my MMM on the wall and some gear oil leaked. Does yours leak when it is on these axles?
/ Mower deck mover #12
It hasn't leaked any yet. It's got approx 150 hrs on it.
It's stowed on the axles around the end of Nov through sometime in Mar.
Volfandt
/ Mower deck mover #13
Mine also leaks when I have it on the axles.
/ Mower deck mover #14
Hang it on the WALL!!! Now you're talking! Of course I have so much hanging off the walls and ceilings already I'm surprised the whole thing doesn't implode.
/ Mower deck mover #15
I use the moweraxle wheels in winter. I take the MMM on and off a lot in summer while using other implements. The cars go out of the garage so I have work space. The anti-scalp wheels are set slightly high and I never rotate them to their perpendicular position. I have a dolly made of 1/2" ply and 16 2" swivel casters. When the deck is dropped to the dolly, the anti-scalps don't touch the ground and the deck rolls around easily on the dolly.
I have an electric hoist suspended from a reinforced truss. A short piece of heavy chain is looped around the axle of the front anti-scalp roller, and both chain ends hooked to the hoist cable. It lifts easily for deck cleaning, blade removal (to sharpen), or to swap out moweraxles. The front anti-scalp roller axle is plenty strong and the deck is well balanced when suspended from it.
/ Mower deck mover #16
The way that my mower deck is shaped, the small mower axels wouldn't work. I had to make my own for clearance.
Ended up with a "Tricycle" setup. I used a pivoting dolly wheel for steering. it's nice to have the room with the deck vertical.
/ Mower deck mover #17
Tom_H said:
........... I have a dolly made of 1/2" ply and 16 2" swivel casters. .............
I can't imagine why you would need 16 casters. Could you please post a picture of the dolly in use and the bottom side with the casters. thanks
APPROX (20) 3" X 4" X 5' TUBING (A64280)
APPROX (20) 3" X...
2025 Auger Drill Bit Mini Skid Steer Attachment (A61572)
2025 Auger Drill...
2023 Case TV620B (A64119)
2023 Case TV620B...
2006 Freightliner Tuscany 4077 40ft Class A Motorhome (A61574)
2006 Freightliner...
New/Unused Mini Quick Attach Pallet Forks (A65583)
New/Unused Mini...
UNUSED SDLANCH SDLL60 STAND ON SKID STEER (A64280)
UNUSED SDLANCH...
