Mowing mower deck lift motor
   / mower deck lift motor #1
greelyjg
massey ferguson 2718
i have a MF 2718 lawn tractor and the mower deck lift motor intermitently stops working. I have by passed all of the switches and applied 12VDC to the motor and it works most of the time but every once in a while it stops working.
if anyone has the correct name for the part or a part number, i'd appreciate it.
   / mower deck lift motor #2
I'm not at all familiar with that tractor, but if you have a DC motor that sometimes stops or fails to start, it sounds like the brushes and/or armature may be in need of attention.
If you can remove the motor without too much trouble, I'd do that and take it to a motor repair shop, unless you're comfortable dismantling it yourself. Often, a new set of brushes and some cleaning on the armature contacts will make it operate like new again. (But don't forget to check out the bearings!)
2018 Toro Workman GTX Electric Utility Cart (A51691)
2018 Toro Workman...
Cat 305.5E CR Excavator (A52384)
Cat 305.5E CR...
2021 John Deere 310SL Backhoe (A53342)
2021 John Deere...
UNUSED CFG INDUSTRIAL MX12RX EXCAVATOR (A51247)
UNUSED CFG...
2016 Kubota RTV-X900 4x4 Utility Cart (A51691)
2016 Kubota...
(APPROX 100) UNUSED FUTURE 10' GALVALUME STEEL (A51248)
(APPROX 100)...
