Mower Deck cleaning
/ Mower Deck cleaning #21
That must be some of that paint where when you are done, it feels like you drank a cold six pack on an empty stomach /forums/images/graemlins/tongue.gif /forums/images/graemlins/tongue.gif
Daryl
Forage Services, L.P.
/ Mower Deck cleaning #22
Slip Plate, less fumes, less expensive and heavier coverage using a bulk can and brush. /forums/images/graemlins/smile.gif
/ Mower Deck cleaning #23
I bought two aerosol cans and a one gallon can from Graingers on Friday. Use some of the aerosol on my hand PH digger and a spade. Plan to use the gallon on the mower deck and inside of the FEL bucket next weekend.
You're right about the fumes from the aerosol though.
Mowed a path through the tall weeds to plant some trees this last weekend. The weeds were kinda wet and none of them stuck to the bottom of the deck. /forums/images/graemlins/cool.gif So far so good..
PS
The fumes have finaly wore off to where I can see straight now. My wife might have a different opinion on that subject..
/ Mower Deck cleaning #25
How did slip plate work out in the long run after using it for a season?
/ Mower Deck cleaning #26
</font><font color="blue" class="small">( How did slip plate work out in the long run after using it for a season? )</font>
I can tell you from my experience that you have to recoat every year, especially if you mow a lot of ground mole hills like I do. /forums/images/graemlins/tongue.gif
Daryl
/ Mower Deck cleaning #27
</font><font color="blue" class="small">( Maybe I'm missing something here. Why do you clean under a mower deck? I used my first Woods rear mount deck for 20 years without cleaning under it, and now I'm into 4 years on my second deck without cleaning under it. Am I doing a big NO, NO?)</font>
I hope you didn't keep the mower in an area that was frequented by homosapiens over the winter. All that rotten moldy grass on the underside of that mower would stink to high heaven. I also suprised that it didn't rust out.
Daryl
/ Mower Deck cleaning #28
I used slip plate on my dirt scoop and it helped the dirt slide right off. The draw back - not very durable, came off over time. I will be painting my mower deck with it this year to see how it handles grass. Stay away from dirt and small gravel or you'll "sandblast" it off.
/ Mower Deck cleaning #29
So, based on your dirt scoop experience, is it safe to suggest you would not recommend Slip Plate for a FEL bucket or a backhoe bucket?
Has anyone else tried it in this type of application?
Bob
/ Mower Deck cleaning #30
</font><font color="blue" class="small">( How did slip plate work out in the long run after using it for a season?)</font>
Oops, I looked at the wrong date and thought this post was started last year. I sprayed the deck on my Craftsman mower deck and hope to try it out this weekend. If it works well, I'll spray the deck on my big mower too, so I'll let you all know how it turns out.
/ Mower Deck cleaning #31
Danny:
I bought a quart of Slip-plate at TSC this week and plan to paint my Craftsman mower deck this weekend, so we may be able to run parallell "tests".
How diligent were you on cleaning your mower deck before you sprayed it? Did you pressure wash it? Steel brush it down to bare (no rust) metal? or somewhere in between?
I was thinking I would pressure wash it and then give it a once over with a wire brush cup on my electric drill.
/ Mower Deck cleaning #32
I painted my Craftsman deck with Slip-Plate from TSC about two weeks back. I scraped/chisled off as much crud as I could, then pressure washed it really good. Let it dry a day and then sprayed 2-3 coats on. I've mowed twice since, but have yet to check to see what's happening underneath there.
I'll post the results when I do check!
/ Mower Deck cleaning #33
Well TSC must be having a run on this stuff just cuz of this thread!!!!! I went out and bought a couple of spray cans and painted my new 60" deck today. Luckily I have only used it for a couple of hours last week to pick up leaves, so cleaning it up wasn't too difficult. Kinda tough to take a perfectly new Kubota orange deck and paint it black!!!! But if this stuff works then I will be very pleased.
Even with the one time I used it so far, it was already coated with grass. It took about 1 1/2 cans to do mine. I probably could have went over it again and used the rest, but I figured I would save it for touch ups later on.
I'll keep you posted once I start mowing as well. Here in NY, the grass is just starting to green up. Probably gonna be another week or two before I really need to mow.
/ Mower Deck cleaning #34
I've tried the used cooking oil on the bottom of the mower deck.. works great, and cleans off easier than motor oil does with mild soap and a hose. Also much better for the environment.
Soundguy
/ Mower Deck cleaning #35
What I ended up doing, Saturday was to scrape/chip away as much of the dried caked on grass, goo and rust I could with a putty knife, alternating with blowing it off with my air compressor. Then I used a paint stripper wheel and a wire brush cup in my electric drill to go over the whole bottom inside. I ended up with some bare metal, some rusty spots and some patches where the dried grass goo wouldn't grind off. I figured if it stood up to my attack it deserved to stay /forums/images/graemlins/wink.gif
Then I slathered on a good coating of Slip-Plate. I got the quart can because it was the same price as two of the 12 oz spray cans. I only used about half the can so there's some left over for touch ups later. From the Slip-Plate literature, the quart can product is more "full bodied" - containing more graphite than the spray cans. It was a cool damp day Saturday so I left the mower deck to dry over night with a small space heater blowing on it.
Sunday morning I buffed the new paint per instructions, mounted the deck and proceeded to mow some pertty dew-wet grass. There was no clogging as there would have been before Slip-Plate and after 3 hours of mowing there was very little build up that I could see without taking the deck off the mower. I didn't do a close inspection nor did I try hosing off the mower deck because I was in a hurry. I'll take a closer look tonight and report.
/ Mower Deck cleaning #36
WVBill - I just pressure washed it (on the highest pressure setting with a 2100 PSI pressure washer) so it was pretty much down to bare metal and let it dry overnight before spraying on 1 can of Slip Plate. It's not a real thick coat, so next time I'll buy the quart can and brush it on. I forgot to buff it up first and mowed the grass, which is damp and lush this time of year, and it still looks pretty clean underneath except for a couple of spots that always seem to build up the worst. I didn't have time to try hosing it off with a garden hose to see how it cleans up. The next time I mow, which won't be long this time of year, I'll try that.
I was in TSC Saturday and noticed they have 2 different brands now (or the company changed their name). They had some cans of Slip Plate and some cans of EZ Slide. The cans are the same green and white as if they wanted to keep people from noticing the difference. I bought 1 can of EZ Slide, since I already have 2 cans of Slip Plate left, and plan to spray my 6' mower deck using Slip Plate on 2/3rds of it and EZ Slide on the other 1/3rd and see how they compare.
/ Mower Deck cleaning #37
I have used Slip-plate for 3 years now on my Kubota G-1800. Stuff works wonders. Of course mowing at the right time also reduces under-deck maintenance headaches and heartaches
/ Mower Deck cleaning #38
I've mowed 2 times now with the Craftsman mower and so far so good. The deck still looks pretty clean and the grass has been damp both times. I sprayed the LandPride 6' deck and haven't mowed with it yet. The EZ Slide is not just Slip Plate with another name, I could tell it was a little different by the way it went on - I had trouble with it running where the Slip Plate didn't run at all, and the EZ Slide was a little shinier. I'll report back after I've mowed with it a couple times.
/ Mower Deck cleaning #39
Here is a secret family recipe that was shared on a previous thread about mower decks clogging up:
<font color="blue"> Ok I know this is supposed to be an old family recipe handed down, and supposed to be kept secret. But here goes. Nothing works forever, but the best substance that I have found is to melt an entire block of sealing wax or parafin (for canning), add a cup of 30 wt motor oil. Pour oil into wax slowly for safeties sake. Using a horse hair brush not nylon. While hot paint the concoction on all exposed surfaces under the deck, and allow to cool overnite. Rememeber that all the exposed areas must be really clean before applying. First I powerwash then I use Castol purple power cleaner at 1/2 ratio let soak a few minutes then powerwash again. As I said nothing lasts forever but this concoction will last 6 to 8 weeks depending on how much or sand dirt your mower picks up. Most grass won't stick or clog and if it does it rinses out with just a garden hoe and nozzle.
P.S. Don't tell my dad I told you.
Russ. Coleman
</font>
/ Mower Deck cleaning #40
/forums/images/graemlins/frown.gifwell, slip plate did not work on my craftsman deck. In fact its hard to tell if theres even any left. I thought i prepped the underside pretty well before i sprayed, but perhaps not. Grass has been dry, but very tall and therefore had a bit of moisture in it anyways. It clogs within 20-30 mins of mowing at the tallest height setting and going super slow. I'm quite sure that the deck is a poor design in the first place, as i've never had this problem with any other mower i've ever owned. Anyways, my "real" tractor should be here in the next 2 weeks, so i'll bush hog it then.
(2) Sets of 200 Amp 13' Jumper Cables (A64912)
(2) Sets of 200...
2026 DEVELON DX27Z-7 EXCAVATOR (A64279)
2026 DEVELON...
2011 FORD CROWN VICTORIA (A66091)
2011 FORD CROWN...
2016 Ford Escape AWD SUV (A66738)
2016 Ford Escape...
2022 Kubota 62in Zero Turn Commercial Mower (A66734)
2022 Kubota 62in...
2016 Autocar ACX Xpeditor T/A New Way 31ASL 31Yd. Side Loader Garbage Truck (A66736)
2016 Autocar ACX...
