Mower Deck cleaning
   / Mower Deck cleaning #1
JimD
Bronze Member
S.E. Michigan
2210 JD
I just purchased a new JD2210 with a 62"deck the old timer at the JD dealer said to coat the bottom of the deck with WD-40 to make it easer to clean off the stuck grass clippings. Has anyone else hear of this? Is there a product out there you can coat the underside of a mower deck to help with the grass removal?
   / Mower Deck cleaning #2
Jim, I don't anything about your deck, but I tried the WD-40 on a Cub Cadet riding mower deck. I also tried some stuff (forgot the name) that a guy at the hardware store recommended. I even repainted the bottom of the deck once. But the best thing I found was to mix 1 quart of motor oil and 3 quarts of diesel, and sprayed a very fine mist on the bottom of the deck before each mowing, then hosed the deck off when I finished mowing.
   / Mower Deck cleaning #3
Best thing I have found is to hose the deck off before mowing (if I am going to mow wet grass, otherwise leave it dry) and look at it before putting it away to see if it needs to be hosed off again. I don't like to put it away wet, so often just blow the tractor and deck off with the high pressure air hose when finished. Anything stuck to the underside of the deck gets knocked off, with a stick or with the air hose.
That works for me, and is the least amount of work in total.
   / Mower Deck cleaning #4
Ooops, I neglected to say that when I "hosed the deck off", I used the air hose even more than the water hose. /forums/images/graemlins/crazy.gif
   / Mower Deck cleaning #5
Something to condsider is waxing the mower deck with a good wax. I have tried that and it helps the grass come off easier. Another thing to try that I haven't is spraying a non stick cooking spray or something to keep the grass from sticking. I know one thing from what I have seen. Do not leave grass on the deck for any amount of time because it will eat the paint quicker than you would believe. At least keep it hosed off after you use it. Hope that helps.
~Dave~
   / Mower Deck cleaning #6
Maybe I'm missing something here. Why do you clean under a mower deck? I used my first Woods rear mount deck for 20 years without cleaning under it, and now I'm into 4 years on my second deck without cleaning under it. Am I doing a big NO, NO?
Gil
   / Mower Deck cleaning #7
You clean under it so that the cut stuff can circulate around the blade(s). Over time the stuff builds up more and more and the clippings only get cut once. This is a bigger deal on, say, a mulching finish deck than it would be on a brush hog.
And I've found that the only way you can really get a deck clean is to turn it over and scrape away at the spots that won't come off with some kind of hand tool that is meant for a completely different purpose, bark your knuckes against the blades, start bleeding, remember that gloves are a good thing, and then start either cursing, crying, or both /forums/images/graemlins/grin.gif.
Just a little joke - although this does represent real experience /forums/images/graemlins/blush.gif. WD-40 doesn't hurt, but I've tried it and am not convinced it really helps all that much. I've waxed the deck, and that helped some, but only for a couple of "mows" and it isn't easy to do. Haven't tried Bird's method, but it sounds good - except I don't always have time to really clean my deck after each mowing /forums/images/graemlins/frown.gif.
   / Mower Deck cleaning #8
Over the years I've coated mower pans with 2-part epoxy bridge paint and industrial Teflon spray coating. I've tried spraying on motor and vegetable oil to. I've hosed the pan off after each usage and also used an air compressor instead of the water. The best low maintenance situation was the industrial Teflon spray coating. It was very difficult to apply and is no longer available, but it usually lasted 2 to 3 seasons. With the Teflon coating the grass literally fell off when you hosed the pan down and the pan did not rust much. Currently, I use a wood paint stirrer to scrape the biggest part of the grass off after each mowing and hose the pan down every once in awhile. What a digression. Gloves are a necessity when scraping the pan. There is a new breed of paint that is used by the municipalities to discourage spray paint taggers. Supposedly, little will stick to it and water blasting can easily remove the taggers paint. It is suppose to adhere extremely well to steel and masonry and is being used for bridge paint. The anti-stick additive is Siloxane. Search on industrial paints that contain Siloxane and read about the characteristics. This paint seems promising, but I could not find it available to consumers. Siloxane
   / Mower Deck cleaning #9
<font color="blue"> This paint seems promising, but I could not find it available to consumers. </font>
It probably isn't. I used to paint for a living, way long ago and even 15 years ago there were a lot of paints that you have to be licensed to get. With the way legislation has been going there are more and more things on the "restricted" list.
Paints can be really nasty chemicals. Very hazardous to apply without the right equipment and equally dangerous if disposed of incorrectly.
The paint stirrer is a good idea, though. I often wind up using metal implements, which scrape off the paint. And when I don't wear gloves, I'm just being careless /forums/images/graemlins/blush.gif.
   / Mower Deck cleaning #10
Ok, I guess I'll have to let you all in on a secret weapon. /forums/images/graemlins/grin.gif <font color="blue">Slip Plate</font> . It is made with graphite. Farmers and industries use it to prevent grain and many other things from sticking to metal surfaces. You can buy it at farm supply stores. Click on the link below to read about it. /forums/images/graemlins/smile.gif
<font color="red">Slip Plate</font>
2017 Ford F-650 Mason Dump Truck (A50323)
2017 Ford F-650...
2018 John Deere 470G Hydraulic Excavator (A50322)
2018 John Deere...
2017 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2017 GENIE GTH-636...
2007 Pace American JT716TA2 20ft T/A Enclosed Trailer (A49461)
2007 Pace American...
20 STEEL FLAT SHEETS (A50854)
20 STEEL FLAT...
