Mower choices
Status
Not open for further replies.
/ Mower choices #1
rbrewer
Have 2 acres to mow and am looking at JD mowers. Suggestions on which is best?
/ Mower choices #2
Well since you decided on a brand already I would say your only limiting factor is wallet size. I also have two acres and am in search of a replacement mower. All I know is I want a 48" or larger deck. My current 36" takes atleast 3 hours to mow. And that is speed mowing in 4th gear. If want it to look nice, 2nd or 3rd gear and about another 1 to 1 1/2 hours.
/ Mower choices #3
I bought a JD L120 and cut 3 acres with it. Has a 48" deck and it saves a lot of time. I did not want to spend the big bucks on a more expensive JD product as my ist mower MTD lasted 13 years (still going) but was not comfortable and had only a 42" deck.
/ Mower choices #4
Allow me to dream a little. GX 345: 20 HP Kawasaki V-twin, power steering, hydraulic lift, 54" deck w/ powerflow bagger. /forums/images/graemlins/wink.gif.
/ Mower choices #5
</font><font color="blue" class="small">( Allow me to dream a little. GX 345: 20 HP Kawasaki V-twin, power steering, hydraulic lift, 54" deck w/ powerflow bagger. /forums/images/graemlins/wink.gif. )</font>
Yep... that would be nice! Probably to the tune of around $8000!
I would go for an LT180 or better.
/ Mower choices
was at the JD dealer and here's ewhat they said....
LT180 42" for $3495
LT190 48" for $3895
LX280 48" for $4295
not sure which...tell me what you think???????????
/ Mower choices #7
I'm thinking there you had a couple earlier threads; so you may have already posted why you want a lawn tractor, but if not, let me throw a twist in things.
The fact you're not looking at GTs, I'm guessing that it doesn't have in ground engaging activities in store. If it is just for cutting grass and maybe a light trailer or something, the $4K marker gets into ZTR machines designed for a couple acres.
These machines have their negatives too [handle different on slopes ect.], but if you have many obstacles it will cetainly save time which also should cut some hours the engine has to run for your mowing tasks.
You're looking at JD, but the Z-Force comes to mind in the CC line up, not to mention a whole slew of commericial manufacturers now marketing "transition" units as well.
Good Luck!
/ Mower choices #8
I just bought a CC GT 2544 with a 44" deck. Its got 2.2 hours on it now, but so far I love it. Give the CC line a good look. My personal opinion is one with shaft drive. My old Cub Cadet (149) is still my back up. I think when I wear this GT 2544 out,
the CC 149 will still be running. 1984 CC 149.
Home from the kill /forums/images/graemlins/grin.gif
/ Mower choices #9
This is the FOURTH thread you have started today on the same topic. Please keep the discussion in the original thread
Status
Auger Cart (A65640)
Auger Cart (A65640)
2019 Chevrolet Silverado 1500 Crew Cab 4X4 Pickup Truck (A60352)
2019 Chevrolet...
Single Cedar Glider (A65583)
Single Cedar...
203201 (A60429)
203201 (A60429)
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
58in Wagon Wheel Bench (A65583)
58in Wagon Wheel...
