Grading Mower blade upgrade
   / Mower blade upgrade #11
I am curious if anybody is or has used the mulching kit in the 60" deck for the BX tractor and if so, how did it perform?
I used one in the 54" deck that I had last year and it was satisfactory but I always found myself going back over the left over small disharged strips. I now have a BX23 with the 60" deck and just puchased the mulching kit for it but do not have it installed yet. The baffle kit is slightly different for it and is made of heavier gage material than the kit for the 54" deck.
If the aforementioned gator blades would fit with this baffle kit installed, maybe that would be a good combination??????
It is my opinion that the Gators would be a good fit for ANYONE, even someone using a push mower bought from wally world. The clippings discharged are decreased significantly. I have contacted Oregon about the proper blades, have yet to hear back from them. Sorry to be so repetitive, but I am really impressed with these, especially after having experimented with mulching kits, with and without mulching blades and so on. I have yet to try adding a baffle or mulching kit but imagine the result would be good.
   / Mower blade upgrade #13
</font><font color="blue" class="small">( Now that's interesting, I look forward to hearing from folks about these. )</font>
It is interesting. I like the concept of small cheap blades.
One thing I wonder about it power. The better a blade mulches, the more power it uses. If a mower has marginal power, I would be afraid it would more likely to bog down than standard blades.
   / Mower blade upgrade #14
Tom …
I am still of the same opinion after buying Meg MO. Stick with factory blades… This is my last reply to this question as to having tried Meg-Mo …
“Yes I have…
A few problems, the first set for my 72” ZTR were cut wrong and didn’t mow right . They did ship another set, but it did not cut evenly. Too much air moving around 12 blades with lift on each one was much too much air and it pushed the grass down instead of lifting it. Nice idea, just dose not work.
I replaced every other blade with a flat knife made for a disk mower, it helped A LOT… but still not as nice a cut as factory blades.
The 4 large circles cut in the round plate do mulch about anything that you mow, that part of the blade is ok, but the over all performance was not to my expectations.
The guy that makes the blades is a nice guy but his blades don’t work on a large deck, they may work fine on a single blade set up. This was 2 years ago they may have corrected the problem? I think you will wish you had just bought $200+ worth of factory blades and used that lifetime supply … keep mowin’… KennyV”
   / Mower blade upgrade #15
Bob you are right about power. To mulch you are cutting the same grass more times and your engine will burn more fuel, generate more heat. It is fortunate that most mowers are over powered to compensate for many different types of mowing. However if you get into too heavy or tall grass and don’t reduce your rate of travel… you will run out of power quicker using a mulch type blade. KennyV.
   / Mower blade upgrade #16
I am running turf tires.
Hootie I got a hold of the Gator guy and they do not make them yet.
Hi,
I am looking for Gator Mulcher Hi Lift blades for a Kubota Bx2230 with a 60" RCK60B mower deck. oem blade #K5371-99040. Are they available?
To: Technical Services and Sales ;
Sent: Monday, August 01, 2005 10:47 AM
Subject: RE: Gator Blades
We do not currently have that blade available.
Thanks for thinking of Oregon(r).
Thanks Jeff,
Is it possible to ream the center hole on a blade of the correct length? Will you be adding these blades in the near future? I have heard great things about your blades and I think they would help with my tire tracks flattening the grass and not lifting it up to be cut.
We have many BX 2230 60" tractors in this area and I think they would be a big seller for you.
Thanks,
It is not easy to ream these blades due to their very hard heat treatment. I also do not suggest that any blade be altered in any way.
I will keep your request in mind for the future.
Now!! If we all contact them maybe they will see the demand for them is out there. Lets make it happen.
As for the post about the mulch kit. I got mine with the deal I wish I would have tried to block the chute first and got the brush bar instead. I hear that that works just as good with Gators and 60" decks.
   / Mower blade upgrade #17
PERCOS2
How about posting the e-mail address you used to contact them? /forums/images/graemlins/grin.gif Then we all can send the same e-mail and see what happens. The more mail they get requesting blades for the 54" and 60" decks they will perhaps make them sooner. /forums/images/graemlins/grin.gif
   / Mower blade upgrade #18
Here is my experience with gator blades for a 50 inch dixon deck.
I will save you the details but after a mixup at my dealer and a wait of about a month I ended up with blades the right lenght but with too small of a hole. Rather than take the blades back to the dealer /forums/images/graemlins/blush.gif I ruined three drill bits and did not do the drill press any good getting about halfway through ONE of the three blades. I ended up taking them to a tool and die shop (one of my in-laws worked there and did it for nothing so I don't have a price but he said it was pretty easy). Anyway after using them for a while on my lawns I found that I liked the way the stock blades distributed the grass clippings better on the lawn, the gator blades produce somewhat smaller clipings but they tend to end up in strips on my lawn I did find that the engine turns about 30 to 40 rpm faster with them on and that they cut very tall grass(like waist high) better without bogging down as much. Untill I got the BX 23 they were my bush hog blades.
   / Mower blade upgrade #19
They will love this. Email address for Gator Blades for our tractors. BX2230's 60"mmm
Martin, Jeff
E-mail Address(es):
Jeff.Martin@oregonoep.com
Jeff Martin
Product Line Coordinator - Blades
Oregon OEP
Phone - 816-920-8312
Fax - 816-920-7506
2015 Ford Explorer XLT 4X4 SUV (A56859)
2015 Ford Explorer...
17201 (A55852)
17201 (A55852)
LINCOLN ELECTRIC RANGER 225 GAS WELDER/GENERATOR (A54757)
LINCOLN ELECTRIC...
2020 CAT 308 (A53317)
John Deere 5103 (A53317)
John Deere 5103...
2018 Ford F-550 (A55973)
2018 Ford F-550...
