mower blade torque
/ mower blade torque #1
Bob_Trevithick
Platinum Member
Williamson, NY (near Rochester)
JD 4300 MFWD
A buddy has an old wheelhorse with MMM, and we used my new air impact wrench to remove and replace his mower blades the other day. My wrench claims to be good for 230 ft/lbs.. should that be enough?
I would have thought it would be more than enough, but he says the first time he tried the deck after the blade switch it made loud clanking noises. We're going to look at it tonight and see if we can figure out what's wrong.
He normally used a very long wrench with a "cheater bar" and gave it everything he had to tighten the blades. I'm thinking that my air wrench probably got them just as tight, and even if it didn't, the problem wouldn't show up immediately, would it? Wouldn't it take at least a few minutes to loosen up enough to make loud noises?
I'll look at my rear finish mower manual when I get home, and see what torque values they recommend for those blades. That should at least get us in the ballpark? Anybody know what typical values are for smaller lawn tractor type mowers?
Any thoughts appreciated!
/ mower blade torque #3
Check the length of the blades. If the new ones are longer, then the tips of the blades are hitting. I put a new set on mine a year or so back and they were an 1/8" longer. Looked like I had the clearance. Boy was I wrong,/w3tcompact/icons/blush.gif made a hell of a clatter when I fired her up./w3tcompact/icons/shocked.gif Ground both ends of the center one and was back in business./w3tcompact/icons/smile.gif Just have to remember which one goes in the center when I sharpen them/w3tcompact/icons/hmm.gif I just tighten them by hand to what I think is right. They have lock washers on them. I think they're only 5/16" bolts.
/ mower blade torque #4
Ahhh, What size deck do you have? The 48" deck has two diferent size blades. The center is about an inch shorter.
I'll bet you guys are right about getting the blades in the wrong position! We'll be working on it in about 20 minutes.. and this is the first thing we will check!
Yes, I think he said it was the 48" deck!
Thanks!! You guys are super!!
/ mower blade torque #6
Sorry to mis lead you Bob, but I mis spoke. Argee was talking about having one blade to long, and I know he has Case tractors, but I see from his profile he has a 42"deck. As far as I know, only the Cases have the one short blade, and only on the 48"deck. But I could be wrong. I hope you find the problem.
Well, it turned out that what had really happened was that we got two washers under one of the blades and none under another. /w3tcompact/icons/blush.gif I guess we were so impressed with the air wrench that we just kind of rushed the job and didn't pay enough attention. He's back up and running now with no problems.
Funny, you could spin the blades by hand and no sign of anything wrong, but spin them up with the engine and she made a terrible clatter.
Anyway, problem solved.. thanks for the assist!! As always, I learned a lot just by the conversation.
Bob
/ mower blade torque #8
I've got a 44" deck. Bought a set of generic blades at the local hardware who carried quite a few different blade sizes. The guy I bought them from owns a Case also. He said they would work. He's the one who ground the center blade down. For free I might add.
/ mower blade torque #9
<font color=red>Bought a set of generic blades at the local hardware who carried quite a few different blade sizes. </font color=red>
?? I did not know you could get aftermarket blades for these. Being reverce rotation, I thought no one made them. Now if I gould just get some mulching blades.
/ mower blade torque #10
Bob,
Glad you got it fixed. It always seems to be the easy things that drive you crazy.
/ mower blade torque #11
Paul,
What side does yours discharge on? Mine discharges to the left. I've heard some of the newer tractors (Ingersoll) discharge on the right,
/ mower blade torque #12
All mine are left discharge. Most mowers are right, and yes the newer Ingersoll ones are. I think they changed when they changed from the 200 and 400 series, to the 3000, and 4000 series.
International 806 Wheatland Tractor (A66285)
International 806...
New Webbing Slings, Polyester, 6:1 & 15" (A62679)
New Webbing...
New/Unused Quick Attach Pallet Forks (A65583)
New/Unused Quick...
2018 FREIGHTLINER M2 FORESTRY UTILITY BUCKET TRUCK (A63276)
2018 FREIGHTLINER...
Bobcat A770 (A60462)
Tennant 5680 (A64127)
