Grading Mower Blade Stuck!!!
   / Mower Blade Stuck!!!
I got that impact wrench for 50$ at lowes
Alex (B8200/HST/4WD/FEL/MidM/Tiller
   / Mower Blade Stuck!!! #12
Alex, there's certainly nothing wrong with buying a cheap one like that, so long as you know what you're getting. I used one that like for many years and it'll probably last a long time if you keep it clean and oiled (be generous with the air tool oil through the air intake). Anyone buying one, though, should look at the specs to see how much torque it puts out. I'll venture a guess that in that price range, you probably have about 250 ft./lbs. That's adequate for a lot of jobs, but I prefer my Ingersoll Rand that goes 425 ft./lbs.
Bird
   / Mower Blade Stuck!!! #14
Don't you love it when you buy something realy good really cheap.
They can keep the extra 25 ft/lbs and you kept the extra $100 with a smile I bet.
Winnipeg, Manitoba
2001 BX2200 All Kubota FEL, Tiller, box blade, blower w/elec shute, 60 mid mt deck, Ag tires.
Grey market B7000 w/Tiller (120 hrs)
1984 JD 316 after 687 hrs.
   / Mower Blade Stuck!!! #15
My pappa always said If it sounds too good to be true, it probibly isn't.
I had a Central Pneumatic (Horrible Freight) brand air impact, rated 450 ft lbs. It couldn't budge a nut (front pulley bolt on a GM 2.5L 4cyl) that spun off with my father-in-laws I-R in less than 5 seconds. I went out the next day and bought a Snap-On. Yeah it costs more, but it's there when you need it. I found its REAL east to publish specs. . . but on Sunday when you try to use the tool and it either won't do the job or it breaks, what-do-ya-do?????
Steve
   / Mower Blade Stuck!!! #16
Alex, if it really is that powerful (and it ought to be if that's the specs on the paperwork), then you got a really good deal.
Bird
   / Mower Blade Stuck!!! #17
Steve, I had one of the Central Pneumatic 1/2" impacts, too./w3tcompact/icons/laugh.gif It was only rated for 250 ft./lbs. and would usually remove lug nuts, but I found lawnmower blades that it wouldn't budge. And I still have a Central Pneumatic butterfly (3/8" impact). No power, but it's fast on easy stuff. If I really needed a 3/8" impact, I'd throw it away and get an Ingersoll.
And like most repair jobs, air tools can be a little daunting at first, but they're actually usually pretty easy to repair if you can get parts at a reasonable price. And if it came from Harbor Freight you're lucky if you can get parts at any price. Snap-on is no better, no worse than Ingersoll Rand or Chicago Pneumatic, but they're really proud of their parts./w3tcompact/icons/frown.gif
But of course, unless you're a professional mechanic using them every day, most of them will probably last a lifetime if they get proper lubrication and no dirt and moisture in them.
Bird
   / Mower Blade Stuck!!! #18
Bird,
I have found a really good use for my Central Pneumatic air tools. I have a neighbor who borrows everything. When he comes for air tools, I give him the CP stuff. He doesn't know I 'm holding back the good stuff (Ingersoll)
   / Mower Blade Stuck!!! #19
A very good idea, Al./w3tcompact/icons/laugh.gif
Bird
well this was a debilviss air power product (misspelling) got the blade off in the lowest setting which was 139ft./lbs I highly doubt that is 400ft./lbs maybe 300ft./lbs
48ft all aluminum feather light wedge trailer (A56435)
48ft all aluminum...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
2025 GIYI MULCHER SKID STEER ATTACHMENT (A58214)
2025 GIYI MULCHER...
Cummins DGCB 60 kW Standby Diesel Generator (A56857)
Cummins DGCB 60 kW...
2014 Ram 1500 4x4 Crew Cab Pickup Truck (A56858)
2014 Ram 1500 4x4...
CAT 930M (A58214)
CAT 930M (A58214)
