Grading Mower blade sharpening
   / Mower blade sharpening #1
JDgreen227
Super Member
Central Michigan
4210 MFWD Ehydro--'89 JD 318
I don't know if anyone else has posted this idea, but it worked well for me. In mid-season I like to sharpen the blades on my 7-Iron deck, but it's heavy and difficult to remove and reinstall. Driving up on ramps gives enough clearance to remove the blades, but it's a pain trying to wedge a wood block into the blades to prevent them from turning while you loosen or tighten the mounting bolts.
My solution is to attach a length of 12/2 electrical wire to a chain grab hook, slip the hook onto the mower blade, and wrap the other end of the wire around something atop the mower deck...it works GREAT.
I am /forums/images/graemlins/mad.gif at myself for not thinking of this trick years ago.
   / Mower blade sharpening #2
Or just use the good old air gun to whizz them off!
Do you have the 60'' 7 iron mounted on your 4000 series tractor? I had one on the 4300 and it cut the best cut you could ever want.
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
6' RAKE (A51243)
6' RAKE (A51243)
2012 UTILITY VS2DX 53FT DRY VAN TRAILER (A52141)
2012 UTILITY VS2DX...
Wolverine Quick Attach 80' Bucket (A50514)
Wolverine Quick...
2014 International 4400 DuraStar Box Truck (A47384)
2014 International...
2016 CATERPILLAR 299D2 SKID STEER (A51242)
2016 CATERPILLAR...
