Mower blade orientation make a difference?
   / Mower blade orientation make a difference? #1
MuncyBob
Platinum Member
N Central PA
PT 422
I remove my blades a few times each year. Sometimes for sharpening and other times I install some old beat up blades when I plan to mow pasture or trails. Even though it's a finish mower deck, if I take care I can clear trails and small brush/saplings fairly easily.
This last time that I put my good blades back on I decided to make the outer blades parallel to each other and then the center blade at 90* to them. It seems I'm getting a better cut and much less wind rows when the grass is a bit thick/tall. Is this my imagination or what?
   / Mower blade orientation make a difference? #2
If you have a drive belt on the deck itself it makes no difference and the next time you hit a log, rock, etc, they will go out of alignment.
Aaron Z
   / Mower blade orientation make a difference? #3
Yep, it won't take long for the orientation to change, or at least it doesn't on ours.
Maybe I just did a good job last time I sharpened them.
   / Mower blade orientation make a difference? #6
Yeah. I never sharpened my blades for years...... then I did and oh my what a difference it makes. Now I do it a couple times a year.
   / Mower blade orientation make a difference? #7
Just pure imagination, as the belt and pulley will have slippage, and the blades after use could be at any angle, and blades could also turn on the shaft due to bolt tightness..
I had one mower, a Troybuilt that had a cogged belt and pulley, and the blades had to be perpendicular to each other, or they might touch/bang each other.
As far as sharpening blades, you can cut a tomato with a sharp knife, or you could karate chop it, but what a difference.
Those people that say that they never sharpen blades are not cutting, but ripping. Besides, it takes less HP using sharp blades.
   / Mower blade orientation make a difference? #8
So, what does "sharp" mean to you? I bought a new set of blades for my ZT. The blades were not "sharp" as I would define the word. I could hold and squeeze the blades without fear of getting cut. The dealer said specifically that the blades should not be sharpened before installation and that a blade that could cut paper was too sharp, would dull very quickly and is unnecessary.
I installed without sharpening and the grass looks cut too me vs. torn. I am not real picky about the grass -- my only issue is that it all gets cut and there are no stragglers.
MoKelly
   / Mower blade orientation make a difference? #9
I imagine if you sharpen to the point of cutting paper, the edge would have less strength because the cross section would be quite small.
   / Mower blade orientation make a difference? #10
The second a sharp blade hits something that is not nice an;d soft, it gets dull. I don't feel I hit anything on my lawnmower but at the end of the year the blades are dented up good.
As I understand it, brush hogs tend to not have sharpened blades, for two reasons. One is that good luck keeping that edge if you are using it for its design, the second is that by breaking, instead of cutting, you increase the chance of killing the plant, which tends to be the more desireable result when brush hogging.
I am going to sharpen, but at the moment I am mired in a dozen other projects so the property is getting long long grass....
2015 ford f350 4x4 mechanic SERVICE TRUCK (A52377)
2015 ford f350 4x4...
2018 JLG 1644 4x4 15,600lb High-Capacity Rough Terrain Telehandler (A52377)
2018 JLG 1644 4x4...
434669 (A48836)
434669 (A48836)
2007 WABASH 53FT DRY VAN TRAILER (A52576)
2007 WABASH 53FT...
2013 FREIGHTLINER CORONADO TANDEM AXLE DAY CAB (A52576)
2013 FREIGHTLINER...
