Mower advice needed
/ Mower advice needed #1
grandpa_e
I am in need of some advice from the vast TBN knowledge base! I finish mow 3.5 acres of the 11 I have. I crrently have a 60" deck for my Kubota B2320. It mows great and gets it done in short order, but the problem is weight. When it rains, which it does a lot here, (Southwest Louisiana) the Kubota ruts up the yard unless it has a week or so to dry out. Th problem is, I often need to mow sooner than that. I also have an old Snapper 30" rear engine mower that I use when its too wet for the tractor. The problem with the snapper is it takes FOREVER to get it all mowed and it is on its last leg. I put a new engine on it a while back, but it's just too small and to worn out. So here is what I need, a small mower in the 48 inch range that can handle somewhat rough yard, very slight hills, several ditches and soft ground. Oh, and cheap would be nice, but I'm not going to kid myself! So, any ideas?
/ Mower advice needed #2
I have the same problem. I just switched from a JD GX345 to a JD X595. Both are great tractors, but now that I switched, the X595 is making ruts, which its never done before, with the GX345
Barrel (A64557)
Barrel (A64557)
2017 Ford F-250 Pickup Truck (A64556)
2017 Ford F-250...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
2026 DEVELON DX27Z-7 EXCAVATOR (A64279)
2026 DEVELON...
2009 PALFINGER 11 FT SERVICE BODY (A62613)
2009 PALFINGER 11...
2015 FORD F350 XL SUPER DUTY BUCKET TRUCK (A63276)
2015 FORD F350 XL...
